[mapserver-dev] MapServer docs and GitHub Process
Steve Lime
sdlime at gmail.com
Mon Sep 21 19:22:03 PDT 2020
+1 on waiting (and discussing side effects)
On Mon, Sep 21, 2020 at 7:46 PM Michael Smith <michael.smith.erdc at gmail.com>
wrote:
> Yeah, we can wait if GitHub makes it seamless.
> Michael Smith
> > On Sep 21, 2020, at 8:41 PM, Jeff McKenna <jmckenna at gatewaygeomatics.com>
> wrote:
> > Mike here is Github's updated advice on renaming master to main:
> https://github.com/github/renaming So on October 1st all newly created
> repositories will default to using main, and "later this year" Github will
> allow a 'seamless move' for this renaming. I think we should wait. Do you
> agree?
> > Option 2 is I think we can use the documentation repository to test the
> renaming, and if successful apply that to the source repository.
> > -jeff
> >> On 2020-09-21 7:10 p.m., michael.smith.erdc at gmail.com wrote:
> >> Would this also be a good time to rename master as main?
> >> Mike
> >>>> On Sep 21, 2020, at 4:23 PM, Jeff McKenna <
> jmckenna at gatewaygeomatics.com> wrote:
> >>> Hi Seth,
> >>> Thanks for mentioning this. Indeed about 6 months ago I set up the
> backport bot for the documentation, but I didn't seem to pull the final
> trigger (this is usually a sign that I had hit a wall).
> >>> I've gone through and configured the backport bot for the
> documentation as well now (had a few failures but it's fixed now).
> >>> Some other points:
> >>> - updated Github settings so that 'master' is now default branch for
> documentation, and changed the message to say to submit PRs to master
> >>> - I also took this time to finally change our old "docs" repository
> name (this goes way back to our CVS days) to something more meaningful:
> "MapServer-documentation". Github handles the appropriate redirects. (
> https://github.com/MapServer/MapServer-documentation)
> >>> - did the same for our "mapserver" Github organization, so that it is
> now "MapServer" (https://github.com/MapServer)
> >>> - I've enabled that Github action 'check-crlf' for the documentation
> workflow, and changed all remaining CRLF linefeeds in the documentation
> files, to LF. Now, when you submit a PR or a push, this checks the entire
> repository for any CRLF linefeeds, and reports a list of files with
> problems, or states "no files with CRLF endings found"
> >>> - also added the git settings that I use locally, to convert to LF
> before commit, to our documentation guide, and made a note of this LF
> requirement (see third point at
> https://mapserver.org/development/documentation.html#github-notes ). But
> this new Github action will nicely tell us about the linefeed problem,
> thanks Seth for mentioning it!
> >>> - regarding the source code directory, I also tried to enable the
> check-crlf, and it found a surprising number of source code files with
> non-LF, but for it to work we'll have to ignore some directories and
> filetypes (such as msautotest, pdfs, etc). There is also a PR for
> check-crlf that adds this, and once that is accepted I'll add this into the
> main source repository as well.
> >>> In summary, we can now use the 'backport branch-7-6' label for
> documentation, and, all pull requests should now we made to master. All
> documentation pull requests are now checked for linefeeds, and a build
> error is thrown if CRLF are found.
> >>> Let me know if any other changes need to be made.
> >>> thanks!
> >>> -jeff
> >>> Jeff McKenna
> >>> MapServer Consulting and Training Services
> >>> co-founder of FOSS4G
> >>> http://gatewaygeo.com/
> >>>> On 2020-09-19 6:38 p.m., Seth G wrote:
> >>>> Hi all,
> >>>> At the moment pull requests to https://github.com/mapserver/docs/
> should be made to the latest active branch (currently 7.6). Documentation
> for new features however should be made to master (as they won't apply to
> new features).
> >>>> Sometimes it is difficult to know if a code change will be backported
> or not.
> >>>> There are several pull requests that have been added to the 7.6
> branch that are not in master, and some in master that are not in 7.6. I'm
> not sure how these possible conflicts are merged following a release
> (likely a painstaking manual process by Jeff?).
> >>>> Would it make sense to follow the same development process as the
> MapServer codebase, and set up the GitHub "backport" bot? Then if code is
> backported the doc pull request can be too, and master will contain all
> updates.
> >>>> Seth
> >>>> web:http://geographika.co.uk
> >>>> twitter: @geographika
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20200921/26951dbd/attachment.html>
