[mapserver-dev] MapServer docs and GitHub Process
Seth G sethg at geographika.co.uk
Tue Sep 22 13:14:27 PDT 2020
Thanks Jeff.
Just trying out the backport bot now.
The CRLF/LF GitHub Action was a suggestion only after a brief search - it didn't seem to be used much - I thought this would be a common requirement. I had a quick look at the source to check it didn't send anything to nefarious URLs.
Seth
web:http://geographika.co.uk
twitter: @geographika
On Mon, Sep 21, 2020, at 10:22 PM, Jeff McKenna wrote:
> Hi Seth,
> Thanks for mentioning this.  Indeed about 6 months ago I set up the
> backport bot for the documentation, but I didn't seem to pull the final
> trigger (this is usually a sign that I had hit a wall).
> I've gone through and configured the backport bot for the documentation
> as well now (had a few failures but it's fixed now).
> Some other points:
> - updated Github settings so that 'master' is now default branch for
> documentation, and changed the message to say to submit PRs to master
> - I also took this time to finally change our old "docs" repository name
> (this goes way back to our CVS days) to something more meaningful:
> "MapServer-documentation".  Github handles the appropriate redirects.
> (https://github.com/MapServer/MapServer-documentation)
> - did the same for our "mapserver" Github organization, so that it is
> now "MapServer" (https://github.com/MapServer)
> - I've enabled that Github action 'check-crlf' for the documentation
> workflow, and changed all remaining CRLF linefeeds in the documentation
> files, to LF.  Now, when you submit a PR or a push, this checks the
> entire repository for any CRLF linefeeds, and reports a list of files
> with problems, or states "no files with CRLF endings found"
> - also added the git settings that I use locally, to convert to LF
> before commit, to our documentation guide, and made a note of this LF
> requirement (see third point at
> https://mapserver.org/development/documentation.html#github-notes ).
> But this new Github action will nicely tell us about the linefeed
> problem, thanks Seth for mentioning it!
> - regarding the source code directory, I also tried to enable the
> check-crlf, and it found a surprising number of source code files with
> non-LF, but for it to work we'll have to ignore some directories and
> filetypes (such as msautotest, pdfs, etc).  There is also a PR for
> check-crlf that adds this, and once that is accepted I'll add this into
> the main source repository as well.
> In summary, we can now use the 'backport branch-7-6' label for
> documentation, and, all pull requests should now we made to master.  All
> documentation pull requests are now checked for linefeeds, and a build
> error is thrown if CRLF are found.
> Let me know if any other changes need to be made.
> thanks!
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> co-founder of FOSS4G
> http://gatewaygeo.com/
> On 2020-09-19 6:38 p.m., Seth G wrote:
> > Hi all,
> > At the moment pull requests to https://github.com/mapserver/docs/ should be made to the latest active branch (currently 7.6). Documentation for new features however should be made to master (as they won't apply to new features).
> > Sometimes it is difficult to know if a code change will be backported or not.
> > There are several pull requests that have been added to the 7.6 branch that are not in master, and some in master that are not in 7.6. I'm not sure how these possible conflicts are merged following a release (likely a painstaking manual process by Jeff?).
> > Would it make sense to follow the same development process as the MapServer codebase, and set up the GitHub "backport" bot? Then if code is backported the doc pull request can be too, and master will contain all updates.
> > Seth
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
