[mapserver-dev] Fuzzing MapServer
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Apr 15 11:33:32 PDT 2021
Here are the specific requirements to join Google's OSS-Fuzz infrastructure:
- To be accepted to OSS-Fuzz, an open-source project must have a
significant user base and/or be critical to the global IT infrastructure
- To apply:
   - Create a pull request with a new
projects/<project_name>/project.yaml file (example) :
https://github.com/google/oss-fuzz/tree/master/projects/libarchive/project.yaml
     - In the file, provide the following information:
          - Your project’s homepage.
          - An email address for the engineering contact to be CCed on
new issues, satisfying the following:
               - The address belongs to an established project committer
(according to VCS logs). If the address isn’t you, or if the address
differs from VCS, we’ll require an informal email verification.
               - The address is associated with a Google account (why?).
       If you use an alternate email address linked to a Google Account,
you’ll only get access to filed bugs in the issue tracker, not to the
ClusterFuzz dashboard. This is due to appengine API limitations.
source:
https://google.github.io/oss-fuzz/getting-started/accepting-new-projects/
Worth a try!  -jeff
On 2021-04-15 2:56 p.m., Jeff McKenna wrote:
> Hi Steve, I've followed other projects closely as they work through
> this, count me in as well, I think a team effort is needed for this as
> it seems to be a lot of work.  Google's "OSS-Fuzz" was launched in 2017
> and most of the big players jumped on board. I'm all for using Google's
> tools for this, use the elephant in the room.
> For some readers out there who might not understand what this 'fuzz'
> thing means, I like this basic description:
> "Fuzzing has been around for donkeys’ years and can best be described as
> a way of robotically bombarding software with random data in an attempt
> to cause the sort of unusual crashes and errors that mimic how programs
> behave under real-world use."  source:
> https://nakedsecurity.sophos.com/2017/05/17/how-big-fuzzing-helps-find-holes-in-open-source-projects/
> -jeff
> On 2021-04-15 2:28 p.m., Steve Lime wrote:
>> I hear what you're saying from a release standpoint. I guess I could
>> have said "initiate a fuzzing effort" as part of the 8.0 release. I
>> like your idea to concentrate on the query string, that represents a
>> pretty big surface depending what the fixed mapfile contains. With
>> oss-fuzz there's a time limit on certain types of bugs before
>> public disclosure, correct? That's a bit worrisome if you got slammed
>> and nobody was available to address bugs.
>> Are there alternatives to oss-fuzz that could be considered (Seth
>> referenced one of them)?
>> Funding would be great although our only source of $'s at the moment
>> is the OSGeo project budget which is really small and partially
>> committed to the TravisCI subscription. Unless there's someone out
>> there that's listening that would like to fund an effort like this.
>> It's definitely something I'd like to work on.
>> --Steve
