[mapserver-dev] mapscriptng - classes all lower case?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Apr 29 12:46:04 PDT 2021
I have not seen that case before. Once installed, you should find the
associated file (containing the MapServer constants and classes) in a
path something like:
/usr/lib/php/xxx/mapscript.php
If you are using today's 'main' checkout, line ~2479 of mapscript.php
should list the "class mapObj" definition.
My servers are mostly Ubuntu, so I am not sure about RHEL8.
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2021-04-29 2:33 p.m., Worth Lutz wrote:
> Hi All,
> We have compiled MapServer with the WITH_PHPNG and find that the classes
> are all lower case.
> $map = new mapobj('mapfile.map');
> instead of
> $map = new mapObj('mapfile.map');
> Has anyone seen this before? What might we be doing wrong?
> This is on RHEL8. We have solved all the other problems but this one is
> stumping us.
> Regards,
> *Worth Lutz*
