[mapserver-dev] MS RFC 133: Mapfile Syntax Cleanup
Steve Lime
sdlime at gmail.com
Mon Feb 1 15:31:40 PST 2021
I don't recall any keyword removals specifically. Should have to touch:
- maplexer.l to remove keywords from the grammar
- mapfile.c/mapfile.h to remove read/write cases and symbols
- mapserver.h to remove structure members
Updating the maplexer.l effectively stops support, the rest is just
cleanup. I'll commit to taking a run through all of these in the next day
or so. It's a long list...
--Steve
On Fri, Jan 29, 2021 at 3:06 PM Seth G <sethg at geographika.co.uk> wrote:
> Hi all,
> I've got round to a draft RFC for cleaning up deprecated and legacy
> Mapfile keywords, based on current docs and going through all the allowed
> syntax as part of mappyfile development and ongoing MapScript docs updates.
> https://mapserver.org/development/rfc/ms-rfc-133.html
> It might be too early to vote on the RFC without some discussion about
> which keywords should be removed.
> In terms of updates any keyword removal would be a separate pull request.
> The changes to mapfile.c seem fine (and the msautotest Mapfiles), but I've
> never used the lexer/parser/Bison process. Are there any sample commits
> when a Mapfile keyword has been removed previously?
> Thoughts/comments welcome,
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210201/8320e918/attachment.html>
