[mapserver-dev] Motion: rename default 'master' branch to 'main'
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Jan 15 13:35:16 PST 2021
Updates: earlier today the default branch for the 'MapServer-demo'
repository was changed to 'main'.
I have recorded the steps to adapt your fork or local clone to the
renamed default branch at
https://github.com/MapServer/MapServer/wiki/Renamed-Default-Branch (with
screencaptures etc).
If you don't want to follow that page, at the minimum you can locally
execute at the commandline, to update your local clone:
git branch -m master main
git fetch origin
git branch -u origin/main main
I am going to proceed with the rest of the 'MapServer organization'
repositories now... (and fix the errors ha)
Wishing all a nice quiet weekend,
-jeff
On 2021-01-13 5:47 p.m., Jeff McKenna wrote:
> Sounds good for testing one repository (and yes to Jerome/MapCache and
> Bruno's request for other projects under the MapServer umbrella).
> Honestly I'm most worried of impacts of the website publishing process,
> but since it is based on a branch other than master it should be ok, but
> I agree to test on 'mapserver-demo'. Maybe this Friday will be the day
> to test.
> (it should be 'easy', but with any change like this there must be some
> undocumented impacts - such as updating the docs for 'master' references
> etc - there will definitely be impacts like that coming, and will try to
> fix them as fast as possible)
> -jeff
> On 2021-01-13 4:50 p.m., Steve Lime wrote:
>> +1 but would it make sense to try with one of the lesser projects
>> (e.g. mapserver-demo) first? That is, before pushing the big red
>> button - fork it, clone it locally, clone the fork and then push the
>> button - and then document the changes necessary to recover.
>> --Steve
>> On Tue, Jan 12, 2021 at 2:54 PM Jeff McKenna
>> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
>> wrote:
>> Hi PSC,
>> Some may remember a past discussion here about possibly renaming our
>> 'master' branch to a less insensitive name as 'main'. It was
>> decided to
>> wait a bit, as Github stated that by January 2021 it would make it
>> easier to change the default branch name
>> (https://github.com/github/renaming
>> <https://github.com/github/renaming>).
>> I have checked our settings today and indeed it is now possible
>> through
>> the regular settings.
>> For our code repository, 'MapServer', here is the dialog window
>> before
>> pressing the 'rename branch' button:
>> https://pasteboard.co/JJlr3xy.png <https://pasteboard.co/JJlr3xy.png>
>> For those not wanting to click an external link, it states that
>> Github
>> will automatically:
>> - update 8 pull requests targeting this branch across 6 repositories
>> - update 1 branch protection rule that explicitly targets 'master'
>> *note that renaming this branch will not update your members' local
>> environments
>> For our documentation repository, 'MapServer-documentation', here is
>> the
>> dialog window before pressing the 'rename branch' button:
>> https://pasteboard.co/JJluDt6.png <https://pasteboard.co/JJluDt6.png>
>> As you can see the impacts on the documentation are less because
>> there
>> are no open pull requests etc.
>> So, it is a good time to move forward with this. Could there be some
>> other impacts? Possibly, but I believe it is worth trying now,
>> and we
>> can adapt if necessary.
>> I motion to rename the default 'master' branch to 'main' for the
>> MapServer and MapServer-documentation repositories.
>> I'll start with a +1
>> PS. happy 2021 to everyone
>> -jeff
