[mapserver-dev] MapServer 8.0 Config File
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Jun 15 10:32:31 PDT 2021
Hi Steve,
I assume that if an admin defines a set of mapfiles in the MAPS section
of the config file, then only those mapfiles would be allowed
(automagically) through CGI etc (therefore removing the difficult setup
of the new MS_MAP_PATTERN environment variables, which unfortunately 99%
of the users will never understand/be able to setup).  Am I
understanding the goal correctly here for this config file?
Put another way: how does defining a mapfile in the MAPS section of the
config file relate to the default MS_MAP_PATTERN & MS_MAP_BAD_PATTERN
(which most users will never understand or be able to setup) ?
So with a secure config file required for the 8.0 release, can we remove
the hardcoded values for MS_MAP_PATTERN & MS_MAP_BAD_PATTERN that are
currently in the source code?
-jeff
On 2021-06-15 2:04 p.m., Steve Lime wrote:
> Hi all: Just checking on folks thoughts on moving forward with a config
> file. There was a bit of discussion back in early April...
> https://github.com/sdlime/mapserver/wiki/MapServer-8.0-Config-File
> <https://github.com/sdlime/mapserver/wiki/MapServer-8.0-Config-File>
> Would be nice to move on it sooner rather than later.
> --Steve
