[mapserver-dev] MapServer 8.0 Config File
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jun 15 11:06:27 PDT 2021
Agreed, it makes sense (also TinyOWS looks for a config file), users
will like this.
-jeff
On 2021-06-15 3:03 p.m., Steve Lime wrote:
> I do think it will be helpful to folks deploying applications like
> yourself. It's very helpful, IMHO, to separate MapServer and web server
> configuration. So to get MapServer and MapCache going you'd set 2
> environment variables that point to the config files and the config
> files would contain the rest. Like the MapCache config file, a sample
> MapServer version can be distributed with copious comments to help users.
> --Steve
> On Tue, Jun 15, 2021 at 12:55 PM Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> wrote:
> I guess I'll be able to answer these questions once I get this working
> inside MS4W. Steve let me know and I'll dive into testing this config
> file.
> I think new users will really like this config file.
> -jeff
> On 2021-06-15 2:32 p.m., Jeff McKenna wrote:
> > Hi Steve,
> > I assume that if an admin defines a set of mapfiles in the MAPS
> section
> > of the config file, then only those mapfiles would be allowed
> > (automagically) through CGI etc (therefore removing the difficult
> setup
> > of the new MS_MAP_PATTERN environment variables, which
> unfortunately 99%
> > of the users will never understand/be able to setup). Am I
> > understanding the goal correctly here for this config file?
> > Put another way: how does defining a mapfile in the MAPS section
> of the
> > config file relate to the default MS_MAP_PATTERN &
> MS_MAP_BAD_PATTERN
> > (which most users will never understand or be able to setup) ?
> > So with a secure config file required for the 8.0 release, can we
> remove
> > the hardcoded values for MS_MAP_PATTERN & MS_MAP_BAD_PATTERN that
> are
> > currently in the source code?
> > -jeff
> > On 2021-06-15 2:04 p.m., Steve Lime wrote:
> >> Hi all: Just checking on folks thoughts on moving forward with a
> >> config file. There was a bit of discussion back in early April...
> https://github.com/sdlime/mapserver/wiki/MapServer-8.0-Config-File
> <https://github.com/sdlime/mapserver/wiki/MapServer-8.0-Config-File>
> <https://github.com/sdlime/mapserver/wiki/MapServer-8.0-Config-File>>
> >> Would be nice to move on it sooner rather than later.
> >> --Steve
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
> Jeff McKenna
> GatewayGeo: Developers of MS4W, MapServer Consulting and Training
> co-founder of FOSS4G
> http://gatewaygeo.com/ <http://gatewaygeo.com/>
Jeff McKenna
