[mapserver-dev] MapServer 8.0 Config File
Daniel Morissette
dmorissette at mapgears.com
Tue Jun 15 18:00:49 PDT 2021
Great addition. A few thoughts/questions:
- Perhaps the default behavior if MS_CONFIG_FILE is not set could be to
look for the config file in /etc/mapserver.conf or
$PREFIX/etc/mapserver.conf ... that would simplify configuration even
more and would be the natural place where one would expect to find such
a config file on Unix/Linux. (Not sure about Windows though)
- If we're going to introduce such a config file, perhaps we should make
it mandatory, and also make MS_MAP_NO_PATH=TRUE the implicit default so
that unless you explicitly change MS_MAP_NO_PATH then only mapfiles
explicitly listed in the config can be used (I know I've always been a
big fan of backwards compatibility, but this time I think it may be
simpler for the users to just deal with a config file that is locked
down by default instead of the complicated/legacy environment variables
in order to secure a server)
- I like Seth's suggestion of being able to set global defaults in the
config file that are inherited by the mapfiles and can be overridden
locally in each one
Daniel
On 2021-06-15 13:04, Steve Lime wrote:
> Hi all: Just checking on folks thoughts on moving forward with a config
> file. There was a bit of discussion back in early April...
> https://github.com/sdlime/mapserver/wiki/MapServer-8.0-Config-File
> <https://github.com/sdlime/mapserver/wiki/MapServer-8.0-Config-File>
> Would be nice to move on it sooner rather than later.
> --Steve
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
Mapgears Inc
T: +1 418-696-5056 #201
