[mapserver-dev] MapServer 8.0 Config File
Steve Lime
sdlime at gmail.com
Sat Jun 19 05:37:51 PDT 2021
More I think about this, I think there shouldn’t be any MapScript impacts.
Call it a CGI config file. That doesn’t preclude something in the future
but it seems sensible to me to leave that out of scope for now.
On Wed, Jun 16, 2021 at 5:21 PM Steve Lime <sdlime at gmail.com> wrote:
> You could certainly store that in one of the hashes "as is" although
> that's potentially a lot of overhead for storing that limited bit of
> information, especially since you have to know the path to the
> configuration file in the first place.
> It seems to me that the most compelling reason for MapScript to leverage
> the config file would be for the global section that Seth mentioned. To
> deal with the globals we need to use the config data as part of the
> initialization process - so it needs to be part of loading or creating a
> map object. That way when you initialize the map you would, for example,
> set the fontset and symbolset attributes based on the global values (if
> present). Then those could be overridden as necessary. Some of the
> environment settings around things like a global debug file and level could
> also be useful in MapScript context.
> So, we'd need to change the msLoadMap() function to take a config
> parameter. This would be mandatory via the CGI and optional for MapScript.
> I could see something like this (Perl):
> $config = new mapscript::configObj('path to config file');
> $map = new mapscript::mapObj('my.map', $config);
> We could create a few helper methods associated with the config to get at
> things but the use of the configuration should be pretty much automatic.
> --Steve
> On Wed, Jun 16, 2021 at 9:34 AM Jeff McKenna <
> jmckenna at gatewaygeomatics.com> wrote:
>> On 2021-06-16 11:06 a.m., Steve Lime wrote:
>> > At the moment this has no impact on MapScript. I was thinking perhaps
>> we
>> > could add a method to optionally load a config file independently of a
>> > mapfile. Thoughts?
>> I believe MapScript impacts was the first comment I had made on this
>> months ago (and it is mentioned in the RFC draft also).
>> For example: PHP SWIG MapScript requires a path to a .php file that
>> contains all MapServer constants & functions (that is installed as part
>> of the cmake steps). For wishlist I'd like to see this new config file
>> allow to set the path to MapScript's required .php file.
>> -jeff
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210619/93bb7394/attachment.html>
