[mapserver-dev] MS RFC 132: Update MapScript API Docs ready for review
Tom Kralidis
tomkralidis at gmail.com
Tue Jun 29 08:41:58 PDT 2021
+1 excellent work!
..Tom
On Tue, Jun 29, 2021 at 11:29 AM Steve Lime <sdlime at gmail.com> wrote:
> Agreed... so +1 from me.
> On Tue, Jun 29, 2021 at 9:02 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Seth,
>> I believe you should just go ahead and merge. Impressive work!
>> Even
>> Le 26/06/2021 à 12:08, Seth G a écrit :
>> Hi all,
>> Any further comments/questions on MS RFC 132?
>> Even raised the question about the `nitpick` being set to False. This is
>> due to the resolution of MapScript variable links, but these can be hidden
>> in Sphinx 4.1 which I believe may be released soon (the mileston deadline
>> was 2 weeks ago). Once we update to Sphinx 4.1 `nitpick` can be set back to
>> True.
>> The other major blocker is getting a pull request into SWIG so class
>> property types are automatically documented.
>> https://github.com/swig/swig/pull/1951 - I'll look again at fixing the
>> tests and trying to get this merged.
>> In the meantime to update the docs requires manually building MapScript
>> with a custom SWIG and pushing to test.pypi.org
>> The pull request in its current state does build the MapScript API docs
>> automatically, and contains over 10 years of updates/corrections to the
>> current MapScript docs so I'd like to merge this into main in the next
>> couple of days if there are no objections.
>> Once merged and the main branch is made to be the current release (8.0)
>> the docs will appear as at:
>> https://geographika.github.io/MapServer-documentation/mapscript/mapscript-api/index.html
>> Seth
>> web:http://geographika.co.uk
>> twitter: @geographika
>> On Tue, May 25, 2021, at 12:11 AM, Steve Lime wrote:
>> Woohoo! Congrats and thanks for taking on such a large chunk of work -
>> two milestones in one day is pretty cool. --Steve
>> On Mon, May 24, 2021 at 8:38 AM Seth G <sethg at geographika.co.uk> wrote:
>> Hi all,
>> I'm pleased to announce that the MapScript documentation generation,
>> described in RFC132 [1] is now added to a pull request [2] ready for
>> review.
>> Features include:
>> * Automatic stub generation based on the latest MapScript release.
>> Keywords and functions.
>> * Any undocumented properties or functions has a TODO label added. The
>> docs will always be up to date with the latest Python MapScript release
>> * Linking to Mapfile keywords to avoid duplication of docs (see Sphinx
>> pull request)
>> * Linking to classes and functions available throughout docs, e.g. in
>> HowTo and in the API docs themselves.
>> * Support for Python snippets from the Python test cases, ensuring
>> examples continue to work with the latest codebase
>> * Set of Python scripts to update the list of available classes,
>> constants, and enumerations, as well as class diagrams. These could also be
>> set these to run automatically as part of the CI / docs build process
>> * Updates to the various MapScript HOWTO guides
>> Seth
>> [1] https://mapserver.org/id/development/rfc/ms-rfc-132.html
>> [2] https://github.com/MapServer/MapServer-documentation/pull/544
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> mapserver-dev mailing listmapserver-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> -- http://www.spatialys.com
>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210629/38453480/attachment.html>
