[mapserver-dev] MS RFC 132: Update MapScript API Docs ready for review
Steve Lime
sdlime at gmail.com
Tue Jun 29 08:28:39 PDT 2021
Agreed... so +1 from me.
On Tue, Jun 29, 2021 at 9:02 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Seth,
> I believe you should just go ahead and merge. Impressive work!
> Even
> Le 26/06/2021 à 12:08, Seth G a écrit :
> Hi all,
> Any further comments/questions on MS RFC 132?
> Even raised the question about the `nitpick` being set to False. This is
> due to the resolution of MapScript variable links, but these can be hidden
> in Sphinx 4.1 which I believe may be released soon (the mileston deadline
> was 2 weeks ago). Once we update to Sphinx 4.1 `nitpick` can be set back to
> True.
> The other major blocker is getting a pull request into SWIG so class
> property types are automatically documented.
> https://github.com/swig/swig/pull/1951 - I'll look again at fixing the
> tests and trying to get this merged.
> In the meantime to update the docs requires manually building MapScript
> with a custom SWIG and pushing to test.pypi.org
> The pull request in its current state does build the MapScript API docs
> automatically, and contains over 10 years of updates/corrections to the
> current MapScript docs so I'd like to merge this into main in the next
> couple of days if there are no objections.
> Once merged and the main branch is made to be the current release (8.0)
> the docs will appear as at:
> https://geographika.github.io/MapServer-documentation/mapscript/mapscript-api/index.html
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Tue, May 25, 2021, at 12:11 AM, Steve Lime wrote:
> Woohoo! Congrats and thanks for taking on such a large chunk of work - two
> milestones in one day is pretty cool. --Steve
> On Mon, May 24, 2021 at 8:38 AM Seth G <sethg at geographika.co.uk> wrote:
> Hi all,
> I'm pleased to announce that the MapScript documentation generation,
> described in RFC132 [1] is now added to a pull request [2] ready for
> review.
> Features include:
> * Automatic stub generation based on the latest MapScript release.
> Keywords and functions.
> * Any undocumented properties or functions has a TODO label added. The
> docs will always be up to date with the latest Python MapScript release
> * Linking to Mapfile keywords to avoid duplication of docs (see Sphinx
> pull request)
> * Linking to classes and functions available throughout docs, e.g. in
> HowTo and in the API docs themselves.
> * Support for Python snippets from the Python test cases, ensuring
> examples continue to work with the latest codebase
> * Set of Python scripts to update the list of available classes,
> constants, and enumerations, as well as class diagrams. These could also be
> set these to run automatically as part of the CI / docs build process
> * Updates to the various MapScript HOWTO guides
> Seth
> [1] https://mapserver.org/id/development/rfc/ms-rfc-132.html
> [2] https://github.com/MapServer/MapServer-documentation/pull/544
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> mapserver-dev mailing listmapserver-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/mapserver-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210629/7260cd0b/attachment-0001.html>
