[mapserver-dev] MS RFC 132: Update MapScript API Docs ready for review
Even Rouault
even.rouault at spatialys.com
Tue Jun 29 07:02:48 PDT 2021
Seth,
I believe you should just go ahead and merge. Impressive work!
Even
Le 26/06/2021 à 12:08, Seth G a écrit :
> Hi all,
> Any further comments/questions on MS RFC 132?
> Even raised the question about the `nitpick` being set to False. This
> is due to the resolution of MapScript variable links, but these can be
> hidden in Sphinx 4.1 which I believe may be released soon (the
> mileston deadline was 2 weeks ago). Once we update to Sphinx 4.1
> `nitpick` can be set back to True.
> The other major blocker is getting a pull request into SWIG so class
> property types are automatically documented.
> https://github.com/swig/swig/pull/1951
> <https://github.com/swig/swig/pull/1951> - I'll look again at fixing
> the tests and trying to get this merged.
> In the meantime to update the docs requires manually building
> MapScript with a custom SWIG and pushing to test.pypi.org
> The pull request in its current state does build the MapScript API
> docs automatically, and contains over 10 years of updates/corrections
> to the current MapScript docs so I'd like to merge this into main in
> the next couple of days if there are no objections.
> Once merged and the main branch is made to be the current release
> (8.0) the docs will appear as at:
> https://geographika.github.io/MapServer-documentation/mapscript/mapscript-api/index.html
> <https://geographika.github.io/MapServer-documentation/mapscript/mapscript-api/index.html>
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Tue, May 25, 2021, at 12:11 AM, Steve Lime wrote:
>> Woohoo! Congrats and thanks for taking on such a large chunk of work
>> - two milestones in one day is pretty cool. --Steve
>> On Mon, May 24, 2021 at 8:38 AM Seth G <sethg at geographika.co.uk
>> <mailto:sethg at geographika.co.uk>> wrote:
>> Hi all,
>> I'm pleased to announce that the MapScript documentation
>> generation, described in RFC132 [1] is now added to a pull
>> request [2] ready for review.
>> Features include:
>> * Automatic stub generation based on the latest MapScript
>> release. Keywords and functions.
>> * Any undocumented properties or functions has a TODO label
>> added. The docs will always be up to date with the latest Python
>> MapScript release
>> * Linking to Mapfile keywords to avoid duplication of docs (see
>> Sphinx pull request)
>> * Linking to classes and functions available throughout docs,
>> e.g. in HowTo and in the API docs themselves.
>> * Support for Python snippets from the Python test cases,
>> ensuring examples continue to work with the latest codebase
>> * Set of Python scripts to update the list of available classes,
>> constants, and enumerations, as well as class diagrams. These
>> could also be set these to run automatically as part of the CI /
>> docs build process
>> * Updates to the various MapScript HOWTO guides
>> Seth
>> [1] https://mapserver.org/id/development/rfc/ms-rfc-132.html
>> <https://mapserver.org/id/development/rfc/ms-rfc-132.html>
>> [2] https://github.com/MapServer/MapServer-documentation/pull/544
>> <https://github.com/MapServer/MapServer-documentation/pull/544>
>> web:http://geographika.co.uk <http://geographika.co.uk>
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210629/3426e044/attachment.html>
