[mapserver-dev] Versioned MapServer Docs?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Mar 18 16:18:44 PDT 2021
As a user I'm constantly relying on those 'added in 5.0' notes, this is
the information that a user needs and craves in the actual user document
(not separate deep in an RFC document). I see these version notes (a
single line that is nicely color coded often) as always relevant, as
users need to know when a parameter was added (and especially those ones
that aren't always fresh & mentioned, such as old 5.0 ones etc).
-jeff
On 2021-03-18 7:23 p.m., Even Rouault wrote:
> My point was too much (no longer relevant) information kills
> information. For the user of Mapserver 7.6, what's the point in seeing
> some feature was added in 4.0 or removed in 5.2 ? That just adds to the
> cognitive load. It might be useful though to see that something was
> added / removed recently and you don't benefit yet from it or are
> dependent on it.
> Le 18/03/2021 à 23:17, Richard Greenwood a écrit :
>> As a guy who has been reading the mapserv docs for 20+ years I'll say
>> that I love the format of the docs in general and specifically the
>> version added, version deprecated, etc. Thanks Jeff and all the other
>> contributors. Hopefully I'll be reading the docs for another 20 years.
>> Rich
>> On Thu, Mar 18, 2021 at 3:18 PM Jeff McKenna
>> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
>> wrote:
>> Ah ok Even, your words sunk into me more now, good points.
>> Although I
>> differ in that I think keeping all of the 'versionadded'
>> references are
>> very important, as this is the rich information that is so priceless
>> (knowing when exactly something was added) for both the users and
>> maintainers of the software/docs. I personally have been making
>> sure to
>> add those 'versionadded' and 'deprecated since' and 'since version'
>> notes into the docs, as this information is so useful to users,
>> even in
>> the case of it being added in 5.0 etc. And as you said, I have to go
>> get that information in the RFC, which users won't know to check, so
>> I've been adding those 'since version' references that you
>> mention, to
>> help users.
>> -jeff
>> On 2021-03-18 5:39 p.m., Even Rouault wrote:
>> > If we keep a single version for simplicity, we could however
>> decide to
>> > clean up a bit the doc content to remove mentions of outdated
>> versions
>> > to avoid cluttering it. There is little point in mentioning any
>> version
>> > older than let's say 5? years ago. I've done that a bit in the
>> GDAL docs
>> > a few months ago, removing any mention of GDAL < 2, considering
>> that all
>> > people looking at the docs would have at least GDAL 2.x something
>> > available, or if they use antiquated stuff, too bad for them.
>> > Looking a bit at download artifacts, for MapServer we could
>> decide for
>> > example that the baseline is MapServer 6.4 (or possibly even 7.0
>> for
>> > simplicity), and remove any mention of that or older versions
>> (except in
>> > RFCs that are reflective of history)
>> > "grep -r versionadded en" in the doc repository shows a number
>> of things
>> > of the 4.x, 5.x or early 6.x eras. 'grep -ri "since version"
>> en' shows
>> > also a number of potential cleanups.
>> > Even
>> > Le 18/03/2021 à 21:15, Jeff McKenna a écrit :
>> >> My preference has always been for Option#1, as it is much
>> easier to
>> >> maintain in my experience, as it is stated clearly as
>> deprecated at
>> >> the parameter level in the document.
>> >> Speaking openly here, if I was paid fulltime to manage the docs
>> and
>> >> all the different build versions of the docs, and publishing them
>> >> online, I could see how that would be possible; but as we are
>> made up
>> >> of volunteers, I would prefer to keep the single version
>> updated with
>> >> references to when the feature was added (what MapServer
>> version), and
>> >> if it is deprecated. I remember recently spending much effort
>> on that
>> >> in-line versioning improvements, I think that is working nicely
>> now.
>> >> -jeff
>> Jeff McKenna
>> GatewayGeo: Developers of MS4W, MapServer Consulting and Training
>> co-founder of FOSS4G
>> http://gatewaygeo.com/ <http://gatewaygeo.com/>
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
>> Richard W. Greenwood, PLS
>> www.greenwoodmap.com <http://www.greenwoodmap.com>
> http://www.spatialys.com
> My software is free, but my time generally not.
Jeff McKenna
