[mapserver-dev] Versioned MapServer Docs?
Brent Fraser bfraser at geoanalytic.com
Fri Mar 19 11:38:50 PDT 2021
Hi Seth,
My problem is getting Sphinx to generate color code syntax highlighting AND add links using .rst.  This discussion encourages me to dig deeper!
With Sphinx:
.. code-block:: mapfile -> syntax highlighting, but no links
.. parsed-literal:: -> links, but no syntax highlighting
There have been a few attempts in the past to make some kind of GUI-based map file generator.  Not sure why they are not more popular.
I think there is great promise in your Python approach.  When a new user approaches MapServer or a consultant gets shipped a shoebox full of shapefiles, one of the more tedious tasks is building a mapfile to render a map.  A Python app to generate a mapfile would go along way to being successful in both of those cases.
In my effort a few years ago, I used Python with GDAL/OGR to read a shapefile and do substitutions in a handcrafted mapfile template to create a finished mapfile (and other XML files related to GeoMoose 2).  Perhaps mappyfile might be a better (more maintainable) method than templates.
Brent
Sent: 3/19/21 12:06 PM
To: "Brent Fraser" <bfraser at geoanalytic.com>, "Basques, Bob (CI-StPaul)" <bob.basques at ci.stpaul.mn.us>, "mapserver-dev at lists.osgeo.org" <mapserver-dev at lists.osgeo.org>
Subject: Re: [mapserver-dev] Versioned MapServer Docs?
Hi Brent,
All Mapfile keywords are linkable using the following format: https://mapserver.org/mapfile/layer.html#mapfile-layer-data
I might "borrow" that idea of linking keywords directly to the docs in the online mappyfile editor.
Longer term I'm hoping to make the JSON schema "official" and bring it into the MapServer project (possible along with mappyfile project itself). See draft RFC at https://mapserver.org/mapfile/layer.html#mapfile-layer-data
mappyfile is also designed to allow plugins (the idea is to allow custom validation plugins for example to check a Mapfile is correctly configured for WMS/WFS for example). Your idea for a mapfile generator could maybe build on mappyfile? At the very least you'd get pretty-printing in Python.
An enjoyable discussion in any case!
Seth
web:http://geographika.co.uk
twitter: @geographika
On Fri, Mar 19, 2021, at 6:39 PM, Brent Fraser wrote:
Good idea, but too much coding for me since it's a lot of work to cover all (most?) of the possibilities.    Seth's mappyfile json files are interesting though; might make it easier.
From: "Basques, Bob (CI-StPaul)" <bob.basques at ci.stpaul.mn.us>
Sent: 3/19/21 11:27 AM
To: "bfraser at geoanalytic.com" <bfraser at geoanalytic.com>, "mapserver-dev at lists.osgeo.org" <mapserver-dev at lists.osgeo.org>, "Jeff McKenna" <jmckenna at gatewaygeomatics.com>
Another thought to consider,  With the HTML option I got to thinking about setting it up as a visual form, where certain elements could be changed in the HTML by the user as FORM elements, and used to create a new Map output tile when submitted.  A way of showing how different parameters/ settings change the output, etc.  sort of a dynamic doc linking thing.
Thanks on the DATA statement, goes to that thought on being able to pass things onto the next curator of the system, probably overkill, but easily readable, etc . . .  I have a real good one for formatting of TEXT inside of the SQL that I should have used.
Bobb
Reply-To: Brent Fraser <bfraser at geoanalytic.com>
Date: Friday, March 19, 2021 at 12:09 PM
To: Bob Basques <bob.basques at ci.stpaul.mn.us>, "mapserver-dev at lists.osgeo.org" <mapserver-dev at lists.osgeo.org>, Jeff McKenna <jmckenna at gatewaygeomatics.com>
Think Before You Click: This email originated outside our organization.
I too use a editor with [imperfect] syntax highlighting (Notepad++).  But i wanted to go beyond that (your Vim -> html is a nice option).
My goals for the "mapfile cheatsheet" are:
1.  Make it easy to create a workable mapfile
 - can simply cut-and paste
 - content should be almost complete
 - have comments showing options, acceptable values, etc for tweaking
2.  Make it available for others to use (e.g. a web page)
3.  Provide links on the keywords pointing to the official doc for details (.rst? .md?)
 - show syntax highlighting for ease of reading
4.  Make it easy to maintain/update as the mapfile syntax changes
Loved your DATA statement by the way!
Brent
mapserver-dev mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210319/8ac28abb/attachment-0001.html>
