[mapserver-dev] GEOS error logging
Steve Lime sdlime at gmail.com
Sat Mar 27 17:02:37 PDT 2021
I don’t think so as implemented but I will have a look at Even’s work.
On Sat, Mar 27, 2021 at 3:50 PM Seth G <sethg at geographika.co.uk> wrote:
> Hi all,
> I'm getting lots of GEOS errors in production logging the following
> messages (the last message is always some junk content):
> msGEOSError(): GEOS library error. @ÞÓV}�
> It is hard to track down the cause of these - presumably invalid input,
> but I'm unsure why and how. It was possible to recreate by passing in NaN
> for example at https://github.com/MapServer/MapServer/issues/6274 - but
> there are other cases with similar errors.
> MapServer allows additional logging for GDAL and PROJ via:
>   CONFIG "CPL_DEBUG" "ON"
>   CONFIG "PROJ_DEBUG" "ON"
> Does anyone know if GEOS have similar logging which MapServer could attach
> to with a similar setup?
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210327/c9be6cc1/attachment.html>
