[mapserver-dev] MS RFC 133: Mapfile Syntax Cleanup
jbo-ads
jbo-ads at mailo.com
Wed Mar 31 09:17:57 PDT 2021
+1
Jérome.
Le 31/03/2021 à 12:25, Tom Kralidis a écrit :
> +1
> ..Tom
> On Wed, Mar 31, 2021 at 4:49 AM thomas bonfort <thomas.bonfort at gmail.com
> <mailto:thomas.bonfort at gmail.com>> wrote:
> +1,
> Thomas
> On Tue, Mar 30, 2021 at 10:58 PM Seth G <sethg at geographika.co.uk
> <mailto:sethg at geographika.co.uk>> wrote:
> __
> Hi Steve,
> I'm not sure where I got CLASS MAXSCALE from - it is not a
> property of the classObj or referenced anywhere in the
> sourcecode/tests. I'll remove from the RFC.
> Anyone else on the PSC more votes on this?
> I'm tempted to merge
> https://github.com/MapServer/MapServer/pull/6264/ (this is
> mainly Steve's work, and then I updated the msautotests), it
> touches a lot of files so may need to be rebased quite often if
> not merged soon.
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Mon, Mar 29, 2021, at 4:54 PM, Steve Lime wrote:
>> Hi Seth: In general I'm a strong +1 on this, anything that
>> simplifies the code base is a good thing.. Only one I wonder
>> about is /CLASS MAXSCALE/ since MINSCALE is currently
>> supported as well? Personally I'm selfish and I really like
>> the MINSCALE/MAXSCALE aliases so retaining those across the
>> board would save me a ton of work when 8.0 arrives.
>> --Steve
>> On Tue, Mar 16, 2021 at 6:08 PM Seth G
>> <sethg at geographika.co.uk <mailto:sethg at geographika.co.uk>> wrote:
>> __
>> Hi all,
>> I've made a start of implementing RFC 133 [1] by removing
>> the now redundant LAYER DUMP keyword [2].
>> It would be good to get some votes in before proceeding
>> further in case people have objections to the overall aim
>> of removing deprecated keywords for the 8.0 release.
>> Any objections to specific keywords being removed can be
>> raised on individual pull requests.
>> Seth
>> [1] https://mapserver.org/development/rfc/ms-rfc-133.html
>> [2] https://github.com/MapServer/MapServer/pull/6264
>> On Tue, Feb 2, 2021, at 11:18 PM, Seth G wrote:
>>> Hi Steve,
>>> If you could do a reference pull request I can use this
>>> as a template for the other keywords.
>>> I guess it needs a vote before accepting, so I'll start
>>> with my +1 - removing ambiguity around keywords will help
>>> new MapServer users. I was adding the DUMP keyword to all
>>> LAYER configs for several years "just in case"...
>>> Seth
>>> On Tue, Feb 2, 2021, at 12:31 AM, Steve Lime wrote:
>>>> I don't recall any keyword removals specifically. Should
>>>> have to touch:
>>>> * maplexer.l to remove keywords from the grammar
>>>> * mapfile.c/mapfile.h to remove read/write cases and
>>>> symbols
>>>> * mapserver.h to remove structure members
>>>> Updating the maplexer.l effectively stops support, the
>>>> rest is just cleanup. I'll commit to taking a run
>>>> through all of these in the next day or so. It's a long
>>>> list...
>>>> --Steve
>>>> On Fri, Jan 29, 2021 at 3:06 PM Seth G
>>>> Hi all,
>>>> I've got round to a draft RFC for cleaning up
>>>> deprecated and legacy Mapfile keywords, based on
>>>> current docs and going through all the allowed
>>>> syntax as part of mappyfile development and ongoing
>>>> MapScript docs updates.
>>>> It might be too early to vote on the RFC without
>>>> some discussion about which keywords should be removed.
>>>> In terms of updates any keyword removal would be a
>>>> separate pull request. The changes to mapfile.c seem
>>>> fine (and the msautotest Mapfiles), but I've never
>>>> used the lexer/parser/Bison process. Are there any
>>>> sample commits when a Mapfile keyword has been
>>>> removed previously?
>>>> Thoughts/comments welcome,
>>>> Seth
>>>> _______________________________________________
>>>> mapserver-dev mailing list
>>>> mapserver-dev at lists.osgeo.org
>>>> <mailto:mapserver-dev at lists.osgeo.org>
>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
