[mapserver-dev] MS RFC 133: Mapfile Syntax Cleanup
Tom Kralidis
tomkralidis at gmail.com
Wed Mar 31 03:25:10 PDT 2021
+1
..Tom
On Wed, Mar 31, 2021 at 4:49 AM thomas bonfort <thomas.bonfort at gmail.com>
wrote:
> +1,
> Thomas
> On Tue, Mar 30, 2021 at 10:58 PM Seth G <sethg at geographika.co.uk> wrote:
>> Hi Steve,
>> I'm not sure where I got CLASS MAXSCALE from - it is not a property of
>> the classObj or referenced anywhere in the sourcecode/tests. I'll remove
>> from the RFC.
>> Anyone else on the PSC more votes on this?
>> I'm tempted to merge https://github.com/MapServer/MapServer/pull/6264/
>> (this is mainly Steve's work, and then I updated the msautotests), it
>> touches a lot of files so may need to be rebased quite often if not merged
>> soon.
>> Seth
>> web:http://geographika.co.uk
>> twitter: @geographika
>> On Mon, Mar 29, 2021, at 4:54 PM, Steve Lime wrote:
>> Hi Seth: In general I'm a strong +1 on this, anything that simplifies the
>> code base is a good thing.. Only one I wonder about is *CLASS MAXSCALE*
>> since MINSCALE is currently supported as well? Personally I'm selfish and I
>> really like the MINSCALE/MAXSCALE aliases so retaining those across the
>> board would save me a ton of work when 8.0 arrives.
>> --Steve
>> On Tue, Mar 16, 2021 at 6:08 PM Seth G <sethg at geographika.co.uk> wrote:
>> Hi all,
>> I've made a start of implementing RFC 133 [1] by removing the now
>> redundant LAYER DUMP keyword [2].
>> It would be good to get some votes in before proceeding further in case
>> people have objections to the overall aim of removing deprecated keywords
>> for the 8.0 release.
>> Any objections to specific keywords being removed can be raised on
>> individual pull requests.
>> Seth
>> [1] https://mapserver.org/development/rfc/ms-rfc-133.html
>> [2] https://github.com/MapServer/MapServer/pull/6264
>> On Tue, Feb 2, 2021, at 11:18 PM, Seth G wrote:
>> Hi Steve,
>> If you could do a reference pull request I can use this as a template for
>> the other keywords.
>> I guess it needs a vote before accepting, so I'll start with my +1 -
>> removing ambiguity around keywords will help new MapServer users. I was
>> adding the DUMP keyword to all LAYER configs for several years "just in
>> case"...
>> Seth
>> On Tue, Feb 2, 2021, at 12:31 AM, Steve Lime wrote:
>> I don't recall any keyword removals specifically. Should have to touch:
>> - maplexer.l to remove keywords from the grammar
>> - mapfile.c/mapfile.h to remove read/write cases and symbols
>> - mapserver.h to remove structure members
>> Updating the maplexer.l effectively stops support, the rest is just
>> cleanup. I'll commit to taking a run through all of these in the next day
>> or so. It's a long list...
>> --Steve
>> On Fri, Jan 29, 2021 at 3:06 PM Seth G <sethg at geographika.co.uk> wrote:
>> Hi all,
>> I've got round to a draft RFC for cleaning up deprecated and legacy
>> Mapfile keywords, based on current docs and going through all the allowed
>> syntax as part of mappyfile development and ongoing MapScript docs updates.
>> It might be too early to vote on the RFC without some discussion about
>> which keywords should be removed.
>> In terms of updates any keyword removal would be a separate pull request.
>> The changes to mapfile.c seem fine (and the msautotest Mapfiles), but I've
>> never used the lexer/parser/Bison process. Are there any sample commits
>> when a Mapfile keyword has been removed previously?
>> Thoughts/comments welcome,
>> Seth
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210331/7a72d2a5/attachment-0001.html>
