[mapserver-dev] MS RFC 133: Mapfile Syntax Cleanup
thomas bonfort
thomas.bonfort at gmail.com
Wed Mar 31 01:49:38 PDT 2021
+1,
Thomas
On Tue, Mar 30, 2021 at 10:58 PM Seth G <sethg at geographika.co.uk> wrote:
> Hi Steve,
> I'm not sure where I got CLASS MAXSCALE from - it is not a property of the
> classObj or referenced anywhere in the sourcecode/tests. I'll remove from
> the RFC.
> Anyone else on the PSC more votes on this?
> I'm tempted to merge https://github.com/MapServer/MapServer/pull/6264/
> (this is mainly Steve's work, and then I updated the msautotests), it
> touches a lot of files so may need to be rebased quite often if not merged
> soon.
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Mon, Mar 29, 2021, at 4:54 PM, Steve Lime wrote:
> Hi Seth: In general I'm a strong +1 on this, anything that simplifies the
> code base is a good thing.. Only one I wonder about is *CLASS MAXSCALE*
> since MINSCALE is currently supported as well? Personally I'm selfish and I
> really like the MINSCALE/MAXSCALE aliases so retaining those across the
> board would save me a ton of work when 8.0 arrives.
> --Steve
> On Tue, Mar 16, 2021 at 6:08 PM Seth G <sethg at geographika.co.uk> wrote:
> Hi all,
> I've made a start of implementing RFC 133 [1] by removing the now
> redundant LAYER DUMP keyword [2].
> It would be good to get some votes in before proceeding further in case
> people have objections to the overall aim of removing deprecated keywords
> for the 8.0 release.
> Any objections to specific keywords being removed can be raised on
> individual pull requests.
> Seth
> [1] https://mapserver.org/development/rfc/ms-rfc-133.html
> [2] https://github.com/MapServer/MapServer/pull/6264
> On Tue, Feb 2, 2021, at 11:18 PM, Seth G wrote:
> Hi Steve,
> If you could do a reference pull request I can use this as a template for
> the other keywords.
> I guess it needs a vote before accepting, so I'll start with my +1 -
> removing ambiguity around keywords will help new MapServer users. I was
> adding the DUMP keyword to all LAYER configs for several years "just in
> case"...
> Seth
> On Tue, Feb 2, 2021, at 12:31 AM, Steve Lime wrote:
> I don't recall any keyword removals specifically. Should have to touch:
> - maplexer.l to remove keywords from the grammar
> - mapfile.c/mapfile.h to remove read/write cases and symbols
> - mapserver.h to remove structure members
> Updating the maplexer.l effectively stops support, the rest is just
> cleanup. I'll commit to taking a run through all of these in the next day
> or so. It's a long list...
> --Steve
> On Fri, Jan 29, 2021 at 3:06 PM Seth G <sethg at geographika.co.uk> wrote:
> Hi all,
> I've got round to a draft RFC for cleaning up deprecated and legacy
> Mapfile keywords, based on current docs and going through all the allowed
> syntax as part of mappyfile development and ongoing MapScript docs updates.
> It might be too early to vote on the RFC without some discussion about
> which keywords should be removed.
> In terms of updates any keyword removal would be a separate pull request.
> The changes to mapfile.c seem fine (and the msautotest Mapfiles), but I've
> never used the lexer/parser/Bison process. Are there any sample commits
> when a Mapfile keyword has been removed previously?
> Thoughts/comments welcome,
> Seth
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210331/da932994/attachment.html>
