[mapserver-dev] Version 8.0, more opt in and less opt out...
Daniel Morissette
dmorissette at mapgears.com
Tue May 18 06:41:36 PDT 2021
FYI mode=OWS was added to deal with OGC compliance testing which
requires the server to produce an exception in some cases if the
SERVICE/REQUEST parameters are missing... and since MapServer falls back
on the CGI mode by default if SERVICE/REQUESTS are not present then the
only way we could imagine to produce that exception and be compliant was
to add a mode=OWS vendor-specific param in the onlineresource. More
info here:
https://github.com/MapServer/MapServer/issues/2512
and
https://github.com/MapServer/MapServer/issues/2531
P.S. I'm following this thread and think it may be a good idea to have
"more opt in and less opt out" for security reasons as long as the
mechanism to handle this is clear and easy to understand, but I don't
have a strong opinion on the proposed changes, that's why I'm staying quiet.
On 2021-05-18 07:58, Steve Lime wrote:
> Hi Even: I'm not sure why "OWS" and "WFS" are in that list. A mode isn't
> required for OWS services of course and so those values must represent a
> special case or work around. Perhaps another dev can weigh in - it's
> odd to see just those two values. The current setup does seem to work as
> expected and you can effectively do things like just support WMS GetMap
> requests and nothing else - including traditional CGI requests. You're
> correct that if the incoming request doesn't contain a mode then mode
> filtering doesn't happen. In that case, if the request isn't an OWS
> request then the mode is set to BROWSE
> (https://github.com/MapServer/MapServer/blob/c862b04cf690091995df40139a6be77a2ff72bce/mapservutil.c#L1770
> <https://github.com/MapServer/MapServer/blob/c862b04cf690091995df40139a6be77a2ff72bce/mapservutil.c#L1770>).
> That value should probably be checked against ms_enable_modes again at
> this point (https://github.com/MapServer/MapServer/issues/6323
> <https://github.com/MapServer/MapServer/issues/6323>).
> Regarding the other area, if you have a mapfile with 5 layers and only
> want to allow runtime changes against one of them you have to do
> something like this for each layer you don't want touched.
> LAYER
> VALIDATION
> IMMUTABLE "any value"
> END
> END
> I don't think this approach makes sense and users should be
> able/required to explicitly define what objects they want to allow
> runtime changes to via the RFC 44 syntax. The validation "hack" doesn't
> work very well and isn't fine grained. I think it would be much better
> to hang a boolean "mutable" property (default = false) off objects that
> are candidates for this sort of limited configuration and then only
> allow changes to those explicitly set to true. The property would not
> cascade. That way a user could limit changes to just a scalebar or to a
> single style in a layer - and nowhere by default.
> SCALEBAR
> MUTABLE TRUE # allow limited configuration at runtime
> END
> --Steve
> On Mon, May 17, 2021 at 1:35 PM Even Rouault <even.rouault at spatialys.com
> <mailto:even.rouault at spatialys.com>> wrote:
> Steve,
> Regarding modes, what would we do regarding OWS requests (I mean
> WMS, WCS, etc.) ? Would that be a mode that needs to be explicitly
> enabled ? I see in mapservutil.c that modeStrings[] contains OWS and
> WFS strings (which aren't documented in
> https://mapserver.org/fr/cgi/controls.html
> <https://mapserver.org/fr/cgi/controls.html>), but if the incoming
> request doesn't contain explicit MODE=OWS or MODE=WFS query
> parameters, mode filtering will not be triggered.
> I haven't understood what you meant with "immutable validation
> value" and what would change. Some example might be useful.
> Even
> Le 17/05/2021 à 19:58, Steve Lime a écrit :
>> Hi all: MapServer has a number of ways to enable/disable CGI-based
>> functionality. For example the /ows_enable_request/ metadata (RFC
>> 67), the /ms_enable_modes/ metadata (RFC 90) or the immutable
>> validation value associated with runtime changes (RFC 44). The
>> latter doesn't seem to be particularly well documented so folks
>> probably don't know it's possible. Of these methods, only
>> ows_enable_request requires users to opt in - you have to
>> explicitly allow OWS services. The other methods require users to
>> opt out. I think we should think about changing that in 8.0 and
>> require explicit configuration by default, so:
>> 1. Require /ms_enable_modes/ be set before handling native
>> MapServer CGI requests or at least set a more limited default
>> than all modes.
>> 2. Consider objects as immutable by default and require users to
>> explicitly configure that at the object-level by adding. Would
>> probably need to extend the VALIDATION block to a few other
>> objects such as scalebars, reference maps and legends. The
>> necessary changes are otherwise not extensive.
>> Note that I consider run-time substitutions as already being
>> explicit since 1) validation is required and 2) users must denote
>> substitution strings as appropriate. Thoughts?
>> --Steve
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
> http://www.spatialys.com <http://www.spatialys.com>
> My software is free, but my time generally not.
Daniel Morissette
Mapgears Inc
T: +1 418-696-5056 #201
