[mapserver-dev] could not load nexrad data
Bruce Clay bclay1297 at gmail.com
Mon Nov 15 09:17:10 PST 2021
I am trying to pull nexrad data from mapserver  to QGIS but it always fails
with the following error as reported in the mapsever error log
[Mon Nov 15 12:07:41 2021].244000 msDrawRasterLayerLow(nexrad_wmst):
entering.
[Mon Nov 15 12:07:41 2021].286000 msPostGISLayerWhichShapes(): Error
(ERROR:  invalid input syntax for type timestamp:
"2021-11-15T10_49:39Z:00:00"
LINE 1: ... ("file_time" between date_trunc('hour',timestamp '2021-11-1...
) executing query: SELECT
"file_path"::text,"file_time"::text,ST_AsBinary(("geom"),'NDR') as
geom,"oid"::text FROM imagery.nexrad WHERE "geom" &&
ST_GeomFromText('POLYGON((-79.9499051833123
24.0232142857143,-79.9499051833123 49.9767857142857,-66.0213337547408
49.9767857142857,-66.0213337547408 24.0232142857143,-79.9499051833123
24.0232142857143))',find_srid('','imagery.nexrad','geom')) AND ("file_time"
between date_trunc('hour',timestamp '2021-11-15T10_49:39Z:00:00') and
date_trunc('hour',timestamp '2021-11-15T10_49:39Z:00:00') + interval '1
hour' - interval '1 second')
[Mon Nov 15 12:07:41 2021].286000 msPostGISLayerWhichShapes(): Query error.
Error executing query. Check server logs
[Mon Nov 15 12:07:41 2021].287000 msDrawMap(): Image handling error. Failed
to draw layer named 'nexrad_wmst'.
I followed the examples I could find on line as best I could.  My map file
entries are as follows.
#  Tile Index
LAYER
 STATUS ON
 NAME "time_idx"
 TYPE POLYGON
 DATA "geom from imagery.nexrad"
  PROJECTION
   "init=epsg:4326"
 END
 METADATA
   "wms_title" "TIME INDEX"
   "wms_srs"   "EPSG:4326"
   "wms_extent" "-126 24 -66 50"
   "wms_timeextent" "2003-08-01/2006-12-31/PT5M"
   "wms_timeitem" "file_time" #column in postgis table of type timestamp
   "wms_timedefault" "2021-11-15T10_49:39Z"
   "wms_enable_request" "*"
 END
 CONNECTIONTYPE postgis
 CONNECTION "host=127.0.0.1 port=5433 dbname=weather user=postgres
password=<pwd>"
END
# raster layer
LAYER
 NAME "nexrad_wmst"
 TYPE RASTER
 STATUS ON
 DEBUG ON
 PROJECTION
   "init=epsg:4326"
 END
 METADATA
   "wms_title" "NEXRAD BASE REF WMS-T"
   "wms_timeextent" "2021-11-14/2021-11-16/PT5M"
   "wms_timeitem" "file_time" #datetime is a column in postgis table of
type timestamp
 END
 OFFSITE 0 0 0
 TILEITEM "file_path" #filepath is a column in postgis table with varchar
of the filepath to each image
 TILEINDEX "time_idx"
 FILTER (`[file_time]` = `2021-11-15 10:49:39`)
END
The data in the database looks like the following
station_id file_path timestamp min_lon min_lat max_lon max_lat
KMVX C:\data_dynamic\weather\ridge2_111521\KMVX_L3_BDHC_20211114_230548.tif
2021-11-14 23:07 -88.82200000 34.42055000 -78.82255000 44.42000000
I do not know where the time format shown in the error message comes from,
presumably from QGIS.  the error occurs when  try to add the nexrad data as
WMS.
The goal is to sequence through the NEXRAD images over time in QGIS.
Any thoughts would be greatly appreciated.
Bruce
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20211115/ae319177/attachment.html>
More information about the MapServer-dev mailing list
