[mapserver-dev] Corrupt MapServer Zip outputs
Even Rouault
even.rouault at spatialys.com
Tue Nov 23 08:22:25 PST 2021
Hi Seth,
> I tried with both of these in the Mapfile, and also setting in the
> command window (SET CPL_CREATE_ZIP64=YES) but still getting a corrupt zip:
> CONFIG "CPL_CREATE_ZIP64" "NO"
> CONFIG "CPL_CREATE_ZIP64" "YES"
> Is there any ogr command to test the low level zip funcion in GDAL?
No
> I thought "ogr2ogr foo.shp.zip something" command was a higher level
> one which meant it might not be using the same approach.
I believe it should be representative enough of how MapServer uses GDAL
zip API.
> I tried both the Windows unzip, 7-zip (x64) and opening on Linux with
> Ark and unzip all with the same errors.
> The strangest thing is that saving via IIS through the browser is
> producing a valid zip using the same OUTPUTFORMAT..
> I'm going to set up the msautotest and roads example in IIS to test if
> that works.
> Could it be related to a change in the Windows cmd shell?
Maybe? But as I mentioned before, I'd thought this would rather be some
msIO_needBinaryStdout() call missing. Perhaps IIS already sets stdout to
binary mode ?
For the sake of testing, what if you add a call to
msIO_needBinaryStdout() in mapserv.c, let's say at
https://github.com/MapServer/MapServer/blob/main/mapserv.c#L243 . I'm
not saying this is necessarily the right fix
Even
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Sun, Nov 21, 2021, at 4:54 PM, Even Rouault wrote:
>> Le 21/11/2021 à 16:43, Seth G a écrit :
>>> Steve - in my case WMS are all fine, it is only related to zipped
>>> outputs using OUTPUTFORMAT blocks.
>>> I was trying to find a working commit for the bisect, but went back
>>> to 7-2 without finding one.
>>> I built MapServer main, and the latest 7-6, 7-4, and 7-2 branches
>>> and ran the msautotest:
>>> cd /D D:\GitHub\mapserver\msautotest\wxs
>>> mapserv -nh
>>> "QUERY_STRING=map=wfs_ogr.map&service=WFS&REQUEST=GetFeature&TYPENAME=road&version=2.0.0&outputformat=shapezip"
>>> > output.zip
>>> All zips were invalid. However the same command does work with the
>>> https://www.gisinternals.com/query.html?content=filelist&file=release-1911-x64-gdal-2-4-4-mapserver-7-4-3.zip
>>> <https://www.gisinternals.com/query.html?content=filelist&file=release-1911-x64-gdal-2-4-4-mapserver-7-4-3.zip>
>>> build. It looks like something changed between GDAL 2.4 and 3.3
>>> Likely function is CPLCreateZip (as this is used by MapServer as
>>> mentioned by Even in the other thread), found in:
>>> https://github.com/OSGeo/gdal/commits/v3.3.3/gdal/port/cpl_minizip_zip.cpp
>>> <https://github.com/OSGeo/gdal/commits/v3.3.3/gdal/port/cpl_minizip_zip.cpp>
>>> There are only a couple of commits between versions that look like
>>> they might be relevant?
>>> https://github.com/OSGeo/gdal/commit/0e159e1ba8ee9e7b4a56bd0b53d16de0acf89485#diff-b156d979e3531903e620bc0616c120584c8e28945247f50b29e81c5a7a49df0b
>>> <https://github.com/OSGeo/gdal/commit/0e159e1ba8ee9e7b4a56bd0b53d16de0acf89485#diff-b156d979e3531903e620bc0616c120584c8e28945247f50b29e81c5a7a49df0b>
>>> https://github.com/OSGeo/gdal/commit/edcdc5b0a57b4fab159b14180141ee42a0408830#diff-b156d979e3531903e620bc0616c120584c8e28945247f50b29e81c5a7a49df0b
>>> <https://github.com/OSGeo/gdal/commit/edcdc5b0a57b4fab159b14180141ee42a0408830#diff-b156d979e3531903e620bc0616c120584c8e28945247f50b29e81c5a7a49df0b>
>>> Is there a test / output zip file in the GDAL tests that could be
>>> used to verify?
>> Not necessarily generated by recent GDAL versions, and if they were,
>> most certainly from Linux builds
>> What is weird is that you reported that .shp.zip files generated by
>> recent gisinternals version with "ogr2ogr foo.shp.zip something" were
>> correct.
>> Hum actually I see that .shp.zip are generated with the
>> CPL_CREATE_ZIP64 environment variable set to NO (the default is YES)
>> Can you try that ?
>> It might be that your .zip reader aren't Zip64 ready, or that GDAL
>> write them in a slightly invalid way
>>> I have a working and invalid zip from msautotest if that helps.
>> yes, could be useful (but I suspect this is a difference between
>> regular ZIP vs Zip64 one)
>>> Seth
>>> web:http://geographika.co.uk <http://geographika.co.uk>
>>> On Sun, Nov 21, 2021, at 3:51 PM, Steve Lime wrote:
>>>> This seems related...
>>>> https://github.com/MapServer/MapServer/issues/6412
>>>> <https://github.com/MapServer/MapServer/issues/6412>
>>>> WMS fails but shp2img works, as does WFS. Could it be WMS specific?
>>>> Would be helpful to try mode=map and see if that works.
>>>> On Sun, Nov 21, 2021 at 8:45 AM Seth G <sethg at geographika.co.uk
>>>> <mailto:sethg at geographika.co.uk>> wrote:
>>>> Thanks Jérome. and Even. Sorry I should have checked for the
>>>> headers in that zip first.
>>>> I'll attempt the bisecting now!
>>>> On Sun, Nov 21, 2021, at 1:12 PM, Even Rouault wrote:
>>>> > Seth,
>>>> > The .zip extension of this test file is a bit misleading, as
>>>> the HTTP
>>>> > headers are not stripped (testing HTTP headers is something
>>>> good to test
>>>> > in some tests). I've issued
>>>> > https://github.com/MapServer/MapServer/pull/6440
>>>> <https://github.com/MapServer/MapServer/pull/6440> to rename
>>>> the expected
>>>> > file though to avoid the confusion
>>>> > You can obtain a valid .zip file without headers with
>>>> > ../../build/mapserv -conf ../etc/mapserv.conf -nh
>>>> QUERY_STRING="map=wfs_ogr.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=road&featureid=road.1521&OUTPUTFORMAT=SHAPEZIP"
>>>> > > out.zip
>>>> > Even
>>>> > Le 21/11/2021 à 12:32, Seth G a écrit :
>>>> >> Hi all,
>>>> >> Following on from the post at
>>>> https://lists.osgeo.org/pipermail/mapserver-users/2021-November/082429.html
>>>> <https://lists.osgeo.org/pipermail/mapserver-users/2021-November/082429.html>
>>>> I've been trying to find where the cause of the corrupt zips
>>>> may be.
>>>> >> There is a msautotest to create zip files and check against
>>>> the expected output, however the expected output also seems to
>>>> be an invalid zip file - I tried on both Windows and Linux.
>>>> >> Even stranger this is both in the main branch (simply
>>>> download the file with the following URL to test), and also
>>>> going back in the history to 2016.
>>>> https://github.com/MapServer/MapServer/blob/main/msautotest/wxs/expected/wfsogr10_shapezip.zip
>>>> <https://github.com/MapServer/MapServer/blob/main/msautotest/wxs/expected/wfsogr10_shapezip.zip>
>>>> >> I had a working process using shapezips in a 7.6 release of
>>>> MapServer so its hard to understand what could have changed,
>>>> MapServer, GDAL, or zip formats themselves?
>>>> >> I'll attempt a Git bisect but if the issue is outside
>>>> MapServer it won't find an issue.
>>>> >> If anyone is able to open the zip file successfully please
>>>> let me know (tried with Ark and unzip on Linux and Windows
>>>> inbuilt unzip and 7-zip on Windows). Error seems to be "87
>>>> extra bytes at beginning or within zip file".
>>>> >> Seth
>>>> >> _______________________________________________
>>>> >> MapServer-dev mailing list
>>>> >> MapServer-dev at lists.osgeo.org
>>>> <mailto:MapServer-dev at lists.osgeo.org>
>>>> >> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>>> <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
>>>> > http://www.spatialys.com <http://www.spatialys.com>
>>>> > My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20211123/cf45bf4c/attachment-0001.html>
More information about the MapServer-dev
