[mapserver-dev] Corrupt MapServer Zip outputs
Seth G
sethg at geographika.co.uk
Tue Nov 23 10:07:37 PST 2021
Hi Even,
No difference when adding in that function call, but I think it is on the right track so will try putting that call in in other places and debugging.
>From the int msIO_needBinaryStdout() comments:
/* But don't do it we are using FastCGI. We will take care of */
/* doing it in the libfcgi library in that case for the normal */
/* cgi case, and for the fastcgi case the _setmode() call */
/* causes a crash. */
I've no problems in my server setups as I'm using FastCGI. As this is on the commandline this is triggered, and I'm guessing it is the same issue for PNGs on the other thread if it is running under CGI rather than FastCGI.
Seth
web:http://geographika.co.uk
twitter: @geographika
On Tue, Nov 23, 2021, at 5:22 PM, Even Rouault wrote:
> Hi Seth,
>> I tried with both of these in the Mapfile, and also setting in the command window (SET CPL_CREATE_ZIP64=YES) but still getting a corrupt zip:
>> CONFIG "CPL_CREATE_ZIP64" "NO"
>> CONFIG "CPL_CREATE_ZIP64" "YES"
>> Is there any ogr command to test the low level zip funcion in GDAL?
> No
>> I thought "ogr2ogr foo.shp.zip something" command was a higher level one which meant it might not be using the same approach.
> I believe it should be representative enough of how MapServer uses GDAL zip API.
>> I tried both the Windows unzip, 7-zip (x64) and opening on Linux with Ark and unzip all with the same errors.
>> The strangest thing is that saving via IIS through the browser is producing a valid zip using the same OUTPUTFORMAT..
>> I'm going to set up the msautotest and roads example in IIS to test if that works.
>> Could it be related to a change in the Windows cmd shell?
> Maybe? But as I mentioned before, I'd thought this would rather be some msIO_needBinaryStdout() call missing. Perhaps IIS already sets stdout to binary mode ?
> For the sake of testing, what if you add a call to msIO_needBinaryStdout() in mapserv.c, let's say at https://github.com/MapServer/MapServer/blob/main/mapserv.c#L243 . I'm not saying this is necessarily the right fix
> Even
>> Seth
>> On Sun, Nov 21, 2021, at 4:54 PM, Even Rouault wrote:
>>> Le 21/11/2021 à 16:43, Seth G a écrit :
>>>> Steve - in my case WMS are all fine, it is only related to zipped outputs using OUTPUTFORMAT blocks.
>>>> I was trying to find a working commit for the bisect, but went back to 7-2 without finding one.
>>>> I built MapServer main, and the latest 7-6, 7-4, and 7-2 branches and ran the msautotest:
>>>> cd /D D:\GitHub\mapserver\msautotest\wxs
>>>> mapserv -nh "QUERY_STRING=map=wfs_ogr.map&service=WFS&REQUEST=GetFeature&TYPENAME=road&version=2.0.0&outputformat=shapezip" > output.zip
>>>> All zips were invalid. However the same command does work with the https://www.gisinternals.com/query.html?content=filelist&file=release-1911-x64-gdal-2-4-4-mapserver-7-4-3.zip build. It looks like something changed between GDAL 2.4 and 3.3
>>>> Likely function is CPLCreateZip (as this is used by MapServer as mentioned by Even in the other thread), found in: https://github.com/OSGeo/gdal/commits/v3.3.3/gdal/port/cpl_minizip_zip.cpp
>>>> There are only a couple of commits between versions that look like they might be relevant?
>>>> https://github.com/OSGeo/gdal/commit/0e159e1ba8ee9e7b4a56bd0b53d16de0acf89485#diff-b156d979e3531903e620bc0616c120584c8e28945247f50b29e81c5a7a49df0b
>>>> https://github.com/OSGeo/gdal/commit/edcdc5b0a57b4fab159b14180141ee42a0408830#diff-b156d979e3531903e620bc0616c120584c8e28945247f50b29e81c5a7a49df0b
>>>> Is there a test / output zip file in the GDAL tests that could be used to verify?
>>> Not necessarily generated by recent GDAL versions, and if they were, most certainly from Linux builds
>>> What is weird is that you reported that .shp.zip files generated by recent gisinternals version with "ogr2ogr foo.shp.zip something" were correct.
>>> Hum actually I see that .shp.zip are generated with the CPL_CREATE_ZIP64 environment variable set to NO (the default is YES)
>>> Can you try that ?
>>> It might be that your .zip reader aren't Zip64 ready, or that GDAL write them in a slightly invalid way
>>>> I have a working and invalid zip from msautotest if that helps.
>>> yes, could be useful (but I suspect this is a difference between regular ZIP vs Zip64 one)
>>>> Seth
>>>> On Sun, Nov 21, 2021, at 3:51 PM, Steve Lime wrote:
>>>>> This seems related...
>>>>> https://github.com/MapServer/MapServer/issues/6412
>>>>> WMS fails but shp2img works, as does WFS. Could it be WMS specific? Would be helpful to try mode=map and see if that works.
>>>>> On Sun, Nov 21, 2021 at 8:45 AM Seth G <sethg at geographika.co.uk> wrote:
>>>>>> Thanks Jérome. and Even. Sorry I should have checked for the headers in that zip first.
>>>>>> I'll attempt the bisecting now!
>>>>>> On Sun, Nov 21, 2021, at 1:12 PM, Even Rouault wrote:
>>>>>> > Seth,
>>>>>> > The .zip extension of this test file is a bit misleading, as the HTTP
>>>>>> > headers are not stripped (testing HTTP headers is something good to test
>>>>>> > in some tests). I've issued
>>>>>> > https://github.com/MapServer/MapServer/pull/6440 to rename the expected
>>>>>> > file though to avoid the confusion
>>>>>> > You can obtain a valid .zip file without headers with
>>>>>> > ../../build/mapserv -conf ../etc/mapserv.conf -nh
>>>>>> > QUERY_STRING="map=wfs_ogr.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=road&featureid=road.1521&OUTPUTFORMAT=SHAPEZIP"
>>>>>> > > out.zip
>>>>>> > Even
>>>>>> > Le 21/11/2021 à 12:32, Seth G a écrit :
>>>>>> >> Hi all,
>>>>>> >> Following on from the post at https://lists.osgeo.org/pipermail/mapserver-users/2021-November/082429.html I've been trying to find where the cause of the corrupt zips may be.
>>>>>> >> There is a msautotest to create zip files and check against the expected output, however the expected output also seems to be an invalid zip file - I tried on both Windows and Linux.
>>>>>> >> Even stranger this is both in the main branch (simply download the file with the following URL to test), and also going back in the history to 2016.
>>>>>> >> https://github.com/MapServer/MapServer/blob/main/msautotest/wxs/expected/wfsogr10_shapezip.zip
>>>>>> >> I had a working process using shapezips in a 7.6 release of MapServer so its hard to understand what could have changed, MapServer, GDAL, or zip formats themselves?
>>>>>> >> I'll attempt a Git bisect but if the issue is outside MapServer it won't find an issue.
>>>>>> >> If anyone is able to open the zip file successfully please let me know (tried with Ark and unzip on Linux and Windows inbuilt unzip and 7-zip on Windows). Error seems to be "87 extra bytes at beginning or within zip file".
>>>>>> >> Seth
>>>>>> >> _______________________________________________
>>>>>> >> MapServer-dev mailing list
>>>>>> >> MapServer-dev at lists.osgeo.org
>>>>>> >> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>>>>> > http://www.spatialys.com
>>>>>> > My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20211123/11773240/attachment.html>
More information about the MapServer-dev
