[mapserver-dev] Is layer type TILEINDEX supported or not?
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Tue Sep 7 01:07:41 PDT 2021
See https://github.com/MapServer/MapServer/issues/6404 and https://www.mapserver.org/ogc/wcs_format.html. The latter has an example about a layer using TYPE TILEINDEX. This type is not documented in https://mapserver.org/mapfile/layer.html. Does TYPE TILEINDEX exist and if it does, in which way it is different from TYPE POLYGON?
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210907/cb5eb7b5/attachment.html>
More information about the MapServer-dev mailing list
