[mapserver-dev] Is layer type TILEINDEX supported or not?
Steve Lime sdlime at gmail.com
Wed Sep 8 06:41:06 PDT 2021
I can confirm that "TYPE TILEINDEX" is valid in a layer.  I believe setting
this TYPE excuses the layer from render and query processing where "TYPE
POLYGON" does not.
--Steve
On Tue, Sep 7, 2021 at 3:07 AM Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> See https://github.com/MapServer/MapServer/issues/6404 and
> https://www.mapserver.org/ogc/wcs_format.html. The latter has an example
> about a layer using TYPE TILEINDEX. This type is not documented in
> https://mapserver.org/mapfile/layer.html. Does TYPE TILEINDEX exist and
> if it does, in which way it is different from TYPE POLYGON?
> -Jukka Rahkonen-
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210908/f86e56fc/attachment.html>
More information about the MapServer-dev mailing list
