[mapserver-dev] Is layer type TILEINDEX supported or not?
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Wed Sep 8 07:01:49 PDT 2021
Thanks Steve,
Perhaps TYPE TILEINDEX should be documented and added to the XML schema if it is considered to be useful https://github.com/MapServer/MapServer/blob/main/xmlmapfile/mapfile.xsd
Hiding automatically from WMS layers may be handy for some users even we usually publish also the tileindex layer for visualizing and feature info queries.
-Jukka-
Lähettäjä: Steve Lime <sdlime at gmail.com>
Lähetetty: keskiviikko 8. syyskuuta 2021 16.41
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Kopio: mapserver-dev at lists.osgeo.org
Aihe: Re: [mapserver-dev] Is layer type TILEINDEX supported or not?
I can confirm that "TYPE TILEINDEX" is valid in a layer. I believe setting this TYPE excuses the layer from render and query processing where "TYPE POLYGON" does not.
--Steve
On Tue, Sep 7, 2021 at 3:07 AM Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
See https://github.com/MapServer/MapServer/issues/6404 and https://www.mapserver.org/ogc/wcs_format.html. The latter has an example about a layer using TYPE TILEINDEX. This type is not documented in https://mapserver.org/mapfile/layer.html. Does TYPE TILEINDEX exist and if it does, in which way it is different from TYPE POLYGON?
-Jukka Rahkonen-
MapServer-dev mailing list
MapServer-dev at lists.osgeo.org<mailto:MapServer-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210908/e5619147/attachment.html>
More information about the MapServer-dev
