[mapserver-dev] Motion: rename shp2img to map2img
Even Rouault even.rouault at spatialys.com
Tue Sep 14 16:21:39 PDT 2021
I'm +1. shp2img/map2img usage is likely mostly as a debugging tool. And
the change to adapt is trivial (or people can create a symlink)
A possibility if we worry about backward compatibility would be also to
modify the CMake install target to create a symlink (probably only on Unix)
Le 15/09/2021 à 01:09, Steve Lime a écrit :
> I'm ambivalent... +0.
> On Tue, Sep 14, 2021 at 5:46 PM Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> wrote:
>     Hi devs,
>     As discussed in the recent PSC meetings, I'd like to move forward
>     with
>     the renaming of the shp2img commandline utility to "map2img" (this
>     was
>     first discussed back on 2020-07-07) to be included for the
>     MapServer 8.0
>     release.  Although it is a minimal change in the source code, it has
>     impacts for the user documentation, packaging, and msautotest, so
>     therefore I've created an RFC to document this major change, RFC 136:
>     https://mapserver.org/development/rfc/ms-rfc-136.html
>     <https://mapserver.org/development/rfc/ms-rfc-136.html>
>     I therefore motion to rename the shp2img utility to 'map2img'.
>     I'll start with a +1
>     -jeff
>     Jeff McKenna
>     GatewayGeo: Developers of MS4W, MapServer Consulting and Training
>     co-founder of FOSS4G
>     http://gatewaygeo.com/ <http://gatewaygeo.com/>
>     _______________________________________________
>     MapServer-dev mailing list
>     MapServer-dev at lists.osgeo.org <mailto:MapServer-dev at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>     <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20210915/6bb2c486/attachment-0001.html>
More information about the MapServer-dev mailing list
