[mapserver-dev] Motion: rename shp2img to map2img
jbo-ads jbo-ads at mailo.com
Wed Sep 15 00:41:29 PDT 2021
+1
I also thought of a transition period with a symlink or a duplicate (the
file is not that big). Moreover a warning at shp2img's launch may be
welcome (e.g. "shp2img is deprecated in favor of map2img and will be
phased out in next versions").
Jérome.
Le 15/09/2021 à 01:21, Even Rouault a écrit :
> I'm +1. shp2img/map2img usage is likely mostly as a debugging tool. And
> the change to adapt is trivial (or people can create a symlink)
> A possibility if we worry about backward compatibility would be also to
> modify the CMake install target to create a symlink (probably only on Unix)
> Le 15/09/2021 à 01:09, Steve Lime a écrit :
>> I'm ambivalent... +0.
>> On Tue, Sep 14, 2021 at 5:46 PM Jeff McKenna
>> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
>> wrote:
>>     Hi devs,
>>     As discussed in the recent PSC meetings, I'd like to move forward
>>     with
>>     the renaming of the shp2img commandline utility to "map2img" (this
>>     was
>>     first discussed back on 2020-07-07) to be included for the
>>     MapServer 8.0
>>     release.  Although it is a minimal change in the source code, it has
>>     impacts for the user documentation, packaging, and msautotest, so
>>     therefore I've created an RFC to document this major change, RFC 136:
>>     https://mapserver.org/development/rfc/ms-rfc-136.html
>>     I therefore motion to rename the shp2img utility to 'map2img'.
>>     I'll start with a +1
>>     -jeff
>>     Jeff McKenna
>>     GatewayGeo: Developers of MS4W, MapServer Consulting and Training
>>     co-founder of FOSS4G
>>     http://gatewaygeo.com/
>>     _______________________________________________
>>     MapServer-dev mailing list
>>     MapServer-dev at lists.osgeo.org <mailto:MapServer-dev at lists.osgeo.org>
>>     https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
More information about the MapServer-dev mailing list
