[mapserver-dev] master MapServer docs online?
Seth G sethg at geographika.co.uk
Fri Sep 17 15:39:22 PDT 2021
Hi all,
I don't believe this is the case, but wanted to ask if the master version of the MapServer docs published anywhere online?
There are a few new documented features it would be useful to link to in the upcoming State of MapServer FOSS4G talk that are only in the master branch of https://github.com/MapServer/MapServer-documentation and not at https://mapserver.org/
Would it be possible to publish both the "latest" release and the "master" docs, using the current approach but pointing to subfolders? Something like:
http://mapserver.github.io/latest/ -> https://mapserver.org/
http://mapserver.github.io/master/ -> https://master.mapserver.org/
Or even use the same branches in https://github.com/MapServer/mapserver.github.io as used for the docs, so all old docs would be available online.
Related discussion at: https://lists.osgeo.org/pipermail/mapserver-dev/2021-March/016369.html
Seth
More information about the MapServer-dev mailing list
