[mapserver-dev] Mapserver 8.0 beta documentation
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Aug 16 05:00:26 PDT 2022
Hi Rich,
Correct, TEMPLATEPATTERN was removed (this is already noted in the
documentation at https://mapserver.org/mapfile/map.html ). If you see
it mentioned elsewhere please let me know.
Regarding MS_MAP_PATTERN, let's let SteveL respond here, and I will
correct the docs (as throughout this 8.0 process I always assumed it was
now required).
Thanks,
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2022-08-16 12:16 a.m., Richard Greenwood wrote:
> Nice work on Mapserver 8.0!
> TEMPLATEPATTERN appears to be gone?
> In the mapserver.conf file documentation it says that MS_MAP_PATTERN is
> required (in the comments) but it's working for me w/o.
More information about the MapServer-dev
