[mapserver-dev] Mapserver 8.0 beta documentation
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Aug 16 05:05:23 PDT 2022
Hi Rich,
I just tested the 8.0.0-beta2 and it is in fact required: "Web
application error. Required configuration value MS_MAP_PATTERN not set".
-jeff
On 2022-08-16 9:00 a.m., Jeff McKenna wrote:
> Hi Rich,
> Correct, TEMPLATEPATTERN was removed (this is already noted in the
> documentation at https://mapserver.org/mapfile/map.html ). If you see
> it mentioned elsewhere please let me know.
> Regarding MS_MAP_PATTERN, let's let SteveL respond here, and I will
> correct the docs (as throughout this 8.0 process I always assumed it was
> now required).
> Thanks,
> -jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
More information about the MapServer-dev
