[mapserver-dev] Mapserver 8.0 beta documentation
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Aug 16 05:06:45 PDT 2022
(I tested in my browser with a CGI MODE=map call)
-jeff
On 2022-08-16 9:05 a.m., Jeff McKenna wrote:
> Hi Rich,
> I just tested the 8.0.0-beta2 and it is in fact required: "Web
> application error. Required configuration value MS_MAP_PATTERN not set".
> -jeff
> On 2022-08-16 9:00 a.m., Jeff McKenna wrote:
>> Hi Rich,
>> Correct, TEMPLATEPATTERN was removed (this is already noted in the
>> documentation at https://mapserver.org/mapfile/map.html ). If you see
>> it mentioned elsewhere please let me know.
>> Regarding MS_MAP_PATTERN, let's let SteveL respond here, and I will
>> correct the docs (as throughout this 8.0 process I always assumed it
>> was now required).
>> Thanks,
>> -jeff
More information about the MapServer-dev
