[mapserver-dev] Mapserver 8.0 beta documentation
Richard Greenwood
richard.greenwood at gmail.com
Tue Aug 16 05:31:06 PDT 2022
Sorry I missed the TEMPLATEPATTERN documentation (reading too quickly in
all the excitement over a new MS version)!
Regarding MS_MAP_PATTERN, I'm doing a WMS GetMap request.
Rich
On Tue, Aug 16, 2022 at 6:07 AM Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> (I tested in my browser with a CGI MODE=map call)
> -jeff
> On 2022-08-16 9:05 a.m., Jeff McKenna wrote:
> > Hi Rich,
> > I just tested the 8.0.0-beta2 and it is in fact required: "Web
> > application error. Required configuration value MS_MAP_PATTERN not set".
> > -jeff
> > On 2022-08-16 9:00 a.m., Jeff McKenna wrote:
> >> Hi Rich,
> >> Correct, TEMPLATEPATTERN was removed (this is already noted in the
> >> documentation at https://mapserver.org/mapfile/map.html ). If you see
> >> it mentioned elsewhere please let me know.
> >> Regarding MS_MAP_PATTERN, let's let SteveL respond here, and I will
> >> correct the docs (as throughout this 8.0 process I always assumed it
> >> was now required).
> >> Thanks,
> >> -jeff
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
Richard W. Greenwood
www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220816/2ab90bbd/attachment.htm>
More information about the MapServer-dev
