[mapserver-dev] Mapserver 8.0 beta documentation
Steve Lime
sdlime at gmail.com
Tue Aug 16 06:10:08 PDT 2022
There are 2 scenarios when you won't get the error Jeff references
when MS_MAP_PATTERN is not set in the config file:
1. If using an map alias (set in the map section of the config file) -
these can only be read from the config file.
2. If MS_MAP_PATTERN is set in the underlying environment - that is, by
the web server. Things are set up to fall back to the environment variables
(we're using GDAL functionality) if they exist for any of the MS* variables.
Do either of these apply?
--Steve
On Tue, Aug 16, 2022 at 7:31 AM Richard Greenwood <
richard.greenwood at gmail.com> wrote:
> Sorry I missed the TEMPLATEPATTERN documentation (reading too quickly in
> all the excitement over a new MS version)!
> Regarding MS_MAP_PATTERN, I'm doing a WMS GetMap request.
> Rich
> On Tue, Aug 16, 2022 at 6:07 AM Jeff McKenna <
> jmckenna at gatewaygeomatics.com> wrote:
>> (I tested in my browser with a CGI MODE=map call)
>> -jeff
>> On 2022-08-16 9:05 a.m., Jeff McKenna wrote:
>> > Hi Rich,
>> > I just tested the 8.0.0-beta2 and it is in fact required: "Web
>> > application error. Required configuration value MS_MAP_PATTERN not
>> set".
>> > -jeff
>> > On 2022-08-16 9:00 a.m., Jeff McKenna wrote:
>> >> Hi Rich,
>> >> Correct, TEMPLATEPATTERN was removed (this is already noted in the
>> >> documentation at https://mapserver.org/mapfile/map.html ). If you
>> see
>> >> it mentioned elsewhere please let me know.
>> >> Regarding MS_MAP_PATTERN, let's let SteveL respond here, and I will
>> >> correct the docs (as throughout this 8.0 process I always assumed it
>> >> was now required).
>> >> Thanks,
>> >> -jeff
>> MapServer-dev mailing list
>> MapServer-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Richard W. Greenwood
> www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220816/f9d0ab7d/attachment-0001.htm>
More information about the MapServer-dev
