[MapServer-dev] Possibly undocumented 8.0 change
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Mon Aug 29 02:58:38 PDT 2022
Hi Richard,
Is your aim with using GROUP without NAME to hide the layer from GetCapabilities so that users cannot see or request that layer separately but only as a member of a group? Like "opaque container" in Geoserver https://docs.geoserver.org/latest/en/user/data/webadmin/layergroups.html
-Jukka Rahkonen-
Lähettäjä: Seth G <sethg at geographika.co.uk>
Lähetetty: maanantai 29. elokuuta 2022 10.45
Vastaanottaja: Richard Greenwood <richard.greenwood at gmail.com>; Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi>
Kopio: MapServer Devs <mapserver-dev at lists.osgeo.org>
Aihe: Re: [MapServer-dev] Possibly undocumented 8.0 change
Hi Richard,
Could you create an issue for this on GitHub?
It looks like it could relate to the move to C++.
Thanks,
Seth
web:https://geographika.net<https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgeographika.net%2F&data=05%7C01%7Cjukka.rahkonen%40maanmittauslaitos.fi%7C740cb7d9adbd462bcdb208da899282d6%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C637973559593824585%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=6tzJpnqQQ7EeDVed5QNDNUILWh2XgP8uVeJvZFUOk%2FI%3D&reserved=0>
twitter: @geographika
On Mon, Aug 29, 2022, at 9:34 AM, Richard Greenwood wrote:
An empty string for the NAME works without error. I set the MS_DEBUGLEVEL to 5 and nothing is written to the error file when this error occurs.
On Mon, Aug 29, 2022 at 12:44 AM Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
What happens if you use an empty NAME?
-Jukka Rahkonen-
Lähettäjä: MapServer-dev <mapserver-dev-bounces at lists.osgeo.org<mailto:mapserver-dev-bounces at lists.osgeo.org>> Puolesta Richard Greenwood
Lähetetty: maanantai 29. elokuuta 2022 9.06
Vastaanottaja: Seth G <sethg at geographika.co.uk<mailto:sethg at geographika.co.uk>>
Kopio: MapServer Devs <mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>>
Yes, it's with a WMS request. Apache throws a 500 error "End of script output before headers". I define a LAYER with a GROUP but no NAME. I don't believe METADATA plays into it because I commented out the METADATA block and it fails in the same way.
On Sun, Aug 28, 2022 at 3:07 PM Seth G <sethg at geographika.co.uk<mailto:sethg at geographika.co.uk>> wrote:
Hi Richard,
Do you have more details - is this when using WMS? Is there an error that appears?
For WMS there is a known conflict between GROUP and wms_layer_group in a METADATA block, but this sounds like something different.
Seth
On Sun, Aug 28, 2022, at 3:53 PM, Richard Greenwood wrote:
I didn't see mention of this in the docs, apologies if I missed it. It appears that as of 8.0 a layer must have a NAME. In the past it has been possible for a layer not to have a NAME if it had a GROUP.
Richard W. Greenwood
www.greenwoodmap.com<https://eur06.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.greenwoodmap.com%2F&data=05%7C01%7Cjukka.rahkonen%40maanmittauslaitos.fi%7C740cb7d9adbd462bcdb208da899282d6%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C637973559593824585%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=kpVMwcC6nx6SjlMQD5BEZ8%2F3g6duQ304WtLiEE%2Fo0O0%3D&reserved=0>
MapServer-dev mailing list
MapServer-dev at lists.osgeo.org<mailto:MapServer-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-dev<https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fmapserver-dev&data=05%7C01%7Cjukka.rahkonen%40maanmittauslaitos.fi%7C740cb7d9adbd462bcdb208da899282d6%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C637973559593980832%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=BgJttttphqxXuS2uU9IG8P7xsUn85uH2gzCKIdcOp7Y%3D&reserved=0>
www.greenwoodmap.com<https://eur06.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.greenwoodmap.com%2F&data=05%7C01%7Cjukka.rahkonen%40maanmittauslaitos.fi%7C740cb7d9adbd462bcdb208da899282d6%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C637973559593980832%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=ew%2FlrO5cHFmes6wUDEJH2pLW5H6b982IbU6zjDbds4E%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220829/42509fba/attachment.htm>
More information about the MapServer-dev
