[MapServer-dev] Accessing FlatGeoBuf (.fgb) in S3 bucket?
Scott
public at postholer.com
Tue Aug 30 10:22:24 PDT 2022
Thanks for the response Bjorn!
Using this without DATA, still returns the same error:
CONNECTIONTYPE OGR
CONNECTION "/vsis3/bucket/path/traceseg.fgb"
Ogrinfo works fine, COG works fine, all aws keys/pw set.
.fgb with it's range requests is ideally suited for cloud
storage/retrieval, like COG for raster. COG/.fgb are the perfect pair
for cloud raster/vector data sources. Yet, I can't get .fgb to work
within a .map file. Ugh!
v8 rc1 ms_error message:
[Tue Aug 30 09:53:20 2022].395601 msOGRFileOpen(): OGR error. Open
failed for OGR connection in layer `traceseg'. File not found or
unsupported format. Check server logs.
[Tue Aug 30 09:53:20 2022].395617 Open failed for OGR connection in
layer `traceseg'.
[Tue Aug 30 09:53:20 2022].395625 msDrawMap(): Image handling error.
Failed to draw layer named 'traceseg'.
Thanks again!
On 8/30/22 09:42, Björn Harrtell wrote:
> Hi Scott,
> The OGR method should work but it might be confusing about naming of
> file vs specified in DATA. Does it work if you omit the DATA parameter
> or set it to the same name as the file name (possibly without extension)?
> The new native FlatGeobuf driver ("CONNECTIONTYPE flatgeobuf") only
> supports local file access. While it could possibly be extended to
> support access via HTTP/HTTPS that would be non-trivial work and I'm not
> sure it's worth it because the overhead of going through OGR is likely
> insignificant when you have network I/O involved.
> PS. I don't quite agree that it's the whole point of the format. :)
> Den tis 30 aug. 2022 kl 16:49 skrev Scott <public at postholer.com
> <mailto:public at postholer.com>>:
> Using mapserver 7.6 or 8rc1 I've been unable to serve .fgb from an S3
> bucket. Local disk works fine as does ogrinfo on S3 .fgb. COG raster
> data works fine off S3.
> Accessing .fgb from cloud storage seems to be the whole point of the
> .fgb format. So, I'm very curious if I'm doing something wrong or is it
> by design.
> Map file configs:
> v8rc1:
> DATA "/vsis3/bucket/path/data.fgb"
> v7.6.4
> CONNECTIONTYPE OGR
> CONNECTION "/vsis3/bucket/path/data.fgb"
> DATA "rm_trace"
> v8rc ms_error log:
> [Fri Aug 26 10:24:13 2022].854479 msDrawMap(): Image handling error.
> Failed to draw layer named 'rm_trace'.
> v7.6.4 ms_error log
> [Fri Aug 26 10:06:59 2022].388096 msOGRFileOpen(): OGR error. Open
> failed for OGR connection in layer `rm_trace'. File not found or
> [Fri Aug 26 10:06:59 2022].388132 Open failed for OGR connection in
> layer `rm_trace'.
> www.postholer.com <http://www.postholer.com>
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org <mailto:MapServer-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
More information about the MapServer-dev
