[mapserver-dev] Projections and CONFIG file in MapServer 8.0
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Jul 6 16:12:26 PDT 2022
Ok thanks Steve, but can you be more specific regarding 'local setting'?
On Windows each FOSS4G software has its own PROJ instance/version and
its own PROJ_LIB variable (yes it's complete disaster, waiting to
happen). So where does the mapfile's PROJ_LIB setting, and then the
System environment variable fit into your 3 ?
Thanks,
-jeff
On 2022-07-06 6:44 p.m., Steve Lime wrote:
> I understand your logic and would agree for most things. However, one
> benefit of the config file is to allow admins to lock things down -
> especially items like environment variable settings that tell MapServer
> to load code. Hence my original response, so 1) config file, 2) web
> server environment, 3) local setting.
> --Steve
> On Wed, Jul 6, 2022 at 4:05 PM Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> wrote:
> Oh don't forget PostGIS' use of that same variable (that's where I hit
> this on servers constantly).
> So, my point is, that the only way we can avoid all this "environment"
> variable chaos is first always use the local mapfile setting, then look
> for .conf, and if neither has this, check the other sources.
> -jeff
> On 2022-07-06 6:01 p.m., Jeff McKenna wrote:
> > I think we have several possibilities: environment var (system
> > variable), web server environment variable (Apache config),
> MapServer
> > .conf, and local mapfile setting.
> > I would say that the local mapfile should always be used first by
> > MapServer, in this order:
> > - check mapfile setting,
> > - if not found, check for MapServer .conf setting,
> > - if not found, check for web server setting
> > - if not found, check for system environment variable
> > - ...else, battle for superiority with the other PROJ_LIB
> settings by
> > the other FOSS4G software on that container
> > Notes:
> > - this shared PROJ_LIB issue is not just for MapServer, but is
> faced by
> > all FOSS4G projects that share this variable. On Windows servers
> now it
> > is common for me to have several PROJ_LIB settings, one for each
> FOSS4G
> > software that depends on (depends on that PROJ version for that
> > software), such as QGIS, GDAL, MapServer, etc. etc. Meaning: f
> you need
> > a job run for one software, enable that specific PROJ_LIB.
> > It's fun :)
> > -jeff
> > On 2022-07-06 5:49 p.m., Steve Lime wrote:
> >> This could/would have been the case in past versions as well,
> right?
> >> So I don't think this is a new issue. IMHO I'd think central config
> >> settings should trump local settings for something like this.
> >> On Wed, Jul 6, 2022 at 2:40 PM Seth G <sethg at geographika.co.uk
> <mailto:sethg at geographika.co.uk>
> <mailto:sethg at geographika.co.uk>>> wrote:
> >> Hi all,
> >> Using MapServer 8.0 beta and FastCGI (on Windows) I'm
> running into
> >> an issue where the PROJ_LIB setting is sometimes set by the
> value in
> >> the CONFIG file and sometimes by the setting in the Mapfile:
> >> CONFIG
> >> ENV
> >> MS_MAP_PATTERN "."
> >> PROJ_LIB "C:/MapServer/bin/proj7/share" #proj7
> >> END
> >> END
> >> Then in a Mapfile:
> >> CONFIG "PROJ_LIB" "C:/MapServer/bin/proj/SHARE" # uses proj6
> >> Requests will use one PROJ setting then switch to another
> seemingly
> >> at random.
> >> Should one always take precedence over the other?
> >> Seth
> >> web:https://geographika.net <https://geographika.net>
> <https://geographika.net <https://geographika.net>>
> >> twitter: @geographika
More information about the MapServer-dev
