[mapserver-dev] Projections and CONFIG file in MapServer 8.0
Steve Lime
sdlime at gmail.com
Wed Jul 6 14:44:14 PDT 2022
I understand your logic and would agree for most things. However, one
benefit of the config file is to allow admins to lock things down -
especially items like environment variable settings that tell MapServer to
load code. Hence my original response, so 1) config file, 2) web server
environment, 3) local setting.
--Steve
On Wed, Jul 6, 2022 at 4:05 PM Jeff McKenna <jmckenna at gatewaygeomatics.com>
wrote:
> Oh don't forget PostGIS' use of that same variable (that's where I hit
> this on servers constantly).
> So, my point is, that the only way we can avoid all this "environment"
> variable chaos is first always use the local mapfile setting, then look
> for .conf, and if neither has this, check the other sources.
> -jeff
> On 2022-07-06 6:01 p.m., Jeff McKenna wrote:
> > I think we have several possibilities: environment var (system
> > variable), web server environment variable (Apache config), MapServer
> > .conf, and local mapfile setting.
> > I would say that the local mapfile should always be used first by
> > MapServer, in this order:
> > - check mapfile setting,
> > - if not found, check for MapServer .conf setting,
> > - if not found, check for web server setting
> > - if not found, check for system environment variable
> > - ...else, battle for superiority with the other PROJ_LIB settings by
> > the other FOSS4G software on that container
> > Notes:
> > - this shared PROJ_LIB issue is not just for MapServer, but is faced by
> > all FOSS4G projects that share this variable. On Windows servers now it
> > is common for me to have several PROJ_LIB settings, one for each FOSS4G
> > software that depends on (depends on that PROJ version for that
> > software), such as QGIS, GDAL, MapServer, etc. etc. Meaning: f you need
> > a job run for one software, enable that specific PROJ_LIB.
> > It's fun :)
> > -jeff
> > On 2022-07-06 5:49 p.m., Steve Lime wrote:
> >> This could/would have been the case in past versions as well, right?
> >> So I don't think this is a new issue. IMHO I'd think central config
> >> settings should trump local settings for something like this.
> >> On Wed, Jul 6, 2022 at 2:40 PM Seth G <sethg at geographika.co.uk
> >> <mailto:sethg at geographika.co.uk>> wrote:
> >> Hi all,
> >> Using MapServer 8.0 beta and FastCGI (on Windows) I'm running into
> >> an issue where the PROJ_LIB setting is sometimes set by the value in
> >> the CONFIG file and sometimes by the setting in the Mapfile:
> >> CONFIG
> >> ENV
> >> MS_MAP_PATTERN "."
> >> PROJ_LIB "C:/MapServer/bin/proj7/share" #proj7
> >> END
> >> END
> >> Then in a Mapfile:
> >> CONFIG "PROJ_LIB" "C:/MapServer/bin/proj/SHARE" # uses proj6
> >> Requests will use one PROJ setting then switch to another seemingly
> >> at random.
> >> Should one always take precedence over the other?
> >> Seth
> >> web:https://geographika.net <https://geographika.net>
> >> twitter: @geographika
> Jeff McKenna
> GatewayGeo: Developers of MS4W, MapServer Consulting and Training
> co-founder of FOSS4G
> http://gatewaygeo.com/
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220706/db7a494d/attachment-0001.htm>
More information about the MapServer-dev
