[mapserver-dev] Proposal/request to implement FlatGeobuf as built-in format
    Jeff McKenna
    jmckenna at gatewaygeomatics.com
    Wed May 18 13:12:00 PDT 2022
Ah I see your point, I will expand that point more in the RFC now...
Your assumption is correct.  Thanks Lars!
-jeff
On 2022-05-18 5:09 p.m., Jeff McKenna wrote:
> Thanks for the positive support Lars, your testing feedback is
> important, and merry Christmas ha.
> Regarding your question, please see the section "3.3 Limitations" of the
> RFC which is supposed to handle your question.
> -jeff
> On 2022-05-18 4:07 p.m., Lars Schylberg wrote:
>> Thanks, Björn and Jeff for the effort to do this.I am eager to start
>> testing soon.As a user I feel that Santa is coming early this year.
>> I also have one question.Is the native FlatGeobuf driver doing the
>> reading without checks, like "VERIFY_BUFFERS" "NO" that you can set in
>> the OGR driver?
>> My inofficial +1
>> Lars Schylberg
>> Den 2022-05-18 kl. 17:09, skrev Steve Lime:
>>> Nice work all - esp. Björn. Evan has a good point that sounds like it
>>> could be addressed. Couple of comments:
>>>  1. I'd like to see a security impact section added just so it's clear
>>>     that it has been thought about. For example, what is behavior if a
>>>     corrupt, invalid or truncated file is accessed.
>>>  2. Does the flatgeobuf directory contain only code specific to
>>>     MapServer or is there a mix of custom code and 3rd party code? If
>>>     there is 3rd party code could there be a discussion about how that
>>>     should be maintained over time?
>>>  3. Are things pinned to a particular version of flatbuf - I assume
>>>     yes and that should be noted.
>>>  4. I'm assuming there are no MapScript issues - might be nice to
>>>     explicitly state that.
>>> --Steve
>>> On Wed, May 18, 2022 at 6:38 AM Even Rouault
>>> <even.rouault at spatialys.com> wrote:
>>>     I'm 0 on this. While this is always nice to see a perf
>>>     improvement, I'm
>>>     somewhat concerned by the duplication of code between MapServer
>>>     and GDAL.
>>>     And from a purely technical point of view, one of my worry is that
>>>     symbol clashes might occur between GDAL and MapServer on the
>>>     common code
>>>     they share in the FlatGeobuf and flatbuffers C++ namespaces. If the
>>>     implementations are not kept in sync (and that will necessarily
>>>     happen
>>>     at some point because we cannot control which GDAL version is
>>> used by
>>>     MapServer), weird things (crashes) could possibly happen at
>>>     runtime (or
>>>     at build time if doing static builds). That worry could be solved by
>>>     possibly having a mapserver:: prefix in front of those namespace
>>>     names
>>>     (can be done with some #define trickery. See
>>> https://github.com/OSGeo/PROJ/blob/9f89c7288e44c64ba234a299b1d5528a54d9d61e/include/proj/util.hpp#L104
>>>     for potential inspiration)
>>>     The interesting take-away from my perspective is that the OGR
>>>     overhead
>>>     for FlatGeobuf is only 5 ms, but 13 ms for Shapefile. So one
>>>     interpretation would be that there's some inefficiency in the OGR
>>>     Shapefile driver vs the native MapServer provider.
>>>     Even
>>>     Le 17/05/2022 à 15:19, Jeff McKenna a écrit :
>>>     > Update: Björn has completed the effort (which now includes several
>>>     > msautotests) and we've created an RFC (137) for the native
>>>     FlatGeobuf
>>>     > support: https://mapserver.org/development/rfc/ms-rfc-137.html
>>>     > I therefore motion to include FlatGeobuf as a native MapServer
>>>     driver,
>>>     > per RFC 137, and maintained by Björn Harrtell.
>>>     > starting with my +1
>>>     > Some other interesting updates:
>>>     > - great to see changes here made through testing benefiting so
>>> many
>>>     > other projects
>>>     > - here is an updated benchmark result (that is mentioned in the
>>>     RFC) :
>>>     >   FlatGeobuf (native) 0.008s
>>>     >   Shapefile (native)  0.010s
>>>     >   FlatGeobuf (OGR)    0.013s
>>>     >   Shapefile (OGR)     0.023s
>>>     >   GeoPackage (OGR)    0.042s
>>>     >   SpatiaLite (OGR)    0.045s
>>>     >   PostGIS (native)    0.053s
>>>     >   GeoJSON (OGR)       0.089s
>>>     > (that was with yesterday's main, GDAL 3.4.3, with MS4W on Windows)
>>>     > - with all this testing done, and the existing FlatGeobuf
>>>     > documentation effort, it will be very easy to add this to the main
>>>     > documentation now...
>>>     > Thanks,
>>>     > -Björn & Jeff
>>>     > On 2022-04-27 3:07 p.m., Jeff McKenna wrote:
>>>     >> Great point Even, here is an updated result:
>>>     >>    Shapefile       0.011s
>>>     >>    FlatGeobuf      0.014s
>>>     >>    Shapefile (OGR) 0.024s
>>>     >>    GeoPackage      0.042s
>>>     >>    SpatiaLite      0.045s
>>>     >>    PostGIS         0.053s
>>>     >>    GeoJSON         0.089s
>>>     >> -jeff
>>>     >> On 2022-04-27 2:09 p.m., Even Rouault wrote:
>>>     >>> Jeff,
>>>     >>> as a data point, perhaps you could enhance your bench with
>>>     >>> shapefiles through OGR ? It would be interesting to have a
>>>     sense of
>>>     >>> the OGR overhead (that will be the same for any OGR supported
>>>     >>> datasource) to have an idea if it is really worth the effort
>>>     to have
>>>     >>> a native FlatGeobuf provider for MapServer w.r.t going through
>>>     OGR
>>>     >>> (it is hard to beat shapefile, and the current difference
>>> between
>>>     >>> shapefile and flatgeobuf is small)
>>>     >>> Even
>>>     >>> Le 26/04/2022 à 12:57, Jeff McKenna a écrit :
>>>     >>>> (to followup from our chat on IRC yesterday)
>>>     >>>> To clarify: this would be a new native format in MapServer,
>>>     such as
>>>     >>>> Shapefile or PostGIS, and the goal would be to not connect to
>>>     >>>> FlatGeobuf through OGR, but instead directly, such as:
>>>     >>>>   DATA countries.fgb
>>>     >>>> instead of:
>>>     >>>>   CONNECTIONTYPE OGR
>>>     >>>>   CONNECTION "countries.fgb"
>>>     >>>>   DATA "countries"
>>>     >>>> This should improve the performance even more.  And it will
>>>     be easy
>>>     >>>> to update the documentation, as the existing files just need
>>>     to be
>>>     >>>> updated (see the new page at
>>>     >>>> https://mapserver.org/input/vector/flatgeobuf.html )
>>>     >>>> Great plan Björn!  I look forward to your Pull Request, ha, and
>>>     >>>> will tackle the documentation changes for you.
>>>     >>>> This is also great news for MapServer, and will give us some
>>>     nice
>>>     >>>> publicity.
>>>     >>>> Thanks so much!
>>>     >>>> -jeff
>>>     >>>> On 2022-04-25 5:57 p.m., Björn Harrtell wrote:
>>>     >>>>> Hi mapserver devs!
>>>     >>>>> I got interested in the subject because of the tests made
>>>     recently
>>>     >>>>> by Jeff that shows the potential of the format. I believe it
>>>     >>>>> should be possible to get significant additional performance
>>>     out
>>>     >>>>> of FlatGeobuf in MapServer if it was built in just like
>>>     Shapefile
>>>     >>>>> support is.
>>>     >>>>> FlatGeobuf C++ implementation is rather small, doesn't
>>>     require any
>>>     >>>>> dependencies, and I don't expect it to require any invasive
>>>     >>>>> changes to existing code.
>>>     >>>>> Would love to get started on this ASAP, if there are no
>>>     >>>>> objections. :)
>>>     >>>>> Regards,
>>>     >>>>> Björn Harrtell
>>>     >> ______
>>>     > _______________________________________________
>>>     > MapServer-dev mailing list
>>>     > MapServer-dev at lists.osgeo.org
>>>     > https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>>     --     http://www.spatialys.com
>>>     My software is free, but my time generally not.
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
More information about the MapServer-dev
