[MapServer-dev] mapserver compiling errors
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Oct 31 07:36:59 PDT 2022
Hi Martin,
I searched the mailing list archives for your same question, and found
your exact question, with the solution: search this mailing list archive
at https://marc.info/?l=mapserver-dev
In summary: those str* are just checks and likely the fatal CMake error
is later in your logs.  Recommend to "rm -rf" that build directory and
re-try (for example, it could be that you are failing on some part of
the CMake build process such as enabling PHPNG MapScript).
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2022-10-29 12:24 p.m., Martin Černý wrote:
> Hello,
>       I have Rocky Linux 9 and Mapserver 8 and I try to compile it. But
> there are some errors (undefined reference to strrstr, strlcat,
> strlcpy). Please help.
> See CMakeError.log ... https://pastebin.com/6FyEhPMc
> Regards
> Martin Cerny
> _
More information about the MapServer-dev mailing list
