[MapServer-dev] mapserver compiling errors
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Oct 31 07:41:08 PDT 2022
Put another way: don't get stuck reading the CMake error log file (I've
been down that rabbit hole before, and that log file mentions errors
that do not affect the MapServer build process) - instead look in your
terminal at the output of the cmake command, there at bottom you should
see the MapServer error (such as related to PNG MapScript, etc.)
Hope that helps,
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2022-10-31 11:36 a.m., Jeff McKenna wrote:
> Hi Martin,
> I searched the mailing list archives for your same question, and found
> your exact question, with the solution: search this mailing list archive
> at https://marc.info/?l=mapserver-dev
> In summary: those str* are just checks and likely the fatal CMake error
> is later in your logs. Recommend to "rm -rf" that build directory and
> re-try (for example, it could be that you are failing on some part of
> the CMake build process such as enabling PHPNG MapScript).
> -jeff
More information about the MapServer-dev
