[MapServer-dev] mapserver compiling errors
Martin Černý
cernym at cesnet.cz
Mon Oct 31 08:00:53 PDT 2022
Hello,
I can see only optional dependencies failed - so it should not
failed completely - please see output:
https://pastebin.com/mn35PqSD
Regards
Martin
Dne 31. 10. 22 v 15:41 Jeff McKenna napsal(a):
> Put another way: don't get stuck reading the CMake error log file
> (I've been down that rabbit hole before, and that log file mentions
> errors that do not affect the MapServer build process) - instead look
> in your terminal at the output of the cmake command, there at bottom
> you should see the MapServer error (such as related to PNG MapScript,
> etc.)
> Hope that helps,
> -jeff
Ing. Martin Cerny
CESNET, z.s.p.o.
Zikova 4,
160 00 Praha 6
Czech Republic
Tel:+420-2-34680289
Gsm:+420-606-719014
Type: application/pkcs7-signature
Desc: Elektronicky podpis S/MIME
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20221031/3e8455a8/attachment.bin>
More information about the MapServer-dev
