[MapServer-dev] mapserver compiling errors
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Oct 31 08:26:55 PDT 2022
Exactly what I meant, now focus your efforts on removing those "CMake
Error" messages in that terminal output, and once you remove those the
build will work. (use the HINTS that are given in each section of that
output, to disable or enable what you need)
Hope that helps,
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2022-10-31 12:00 p.m., Martin Černý wrote:
> Hello,
> I can see only optional dependencies failed - so it should not
> failed completely - please see output:
> https://pastebin.com/mn35PqSD
> Regards
> Martin
> Dne 31. 10. 22 v 15:41 Jeff McKenna napsal(a):
>> Put another way: don't get stuck reading the CMake error log file
>> (I've been down that rabbit hole before, and that log file mentions
>> errors that do not affect the MapServer build process) - instead look
>> in your terminal at the output of the cmake command, there at bottom
>> you should see the MapServer error (such as related to PNG MapScript,
>> etc.)
>> Hope that helps,
>> -jeff
More information about the MapServer-dev
