[MapServer-dev] Variables in mapfiles
Steve Lime
sdlime at gmail.com
Tue Dec 26 13:57:00 PST 2023
As a follow up. My previous message was inaccurate and kind of dumb on my
part. You only have to set a default value with no validation block for
things to basically function as a variable with runtime subs. MapServer
will not try to do a substitution if a validation expression is not set and
will automatically fall back to the default value. So, you just need:
"variable_default" "some value"
in a validation block and then you'd reference "%variable%" in supported
locations. Passing variable= in the request will have no effect.
If we allowed "some value" to reference an environment variable (maybe with
a leading $ in the default value) then I could see where that might be a
pretty useful way to externalize some configuration information. We might
consider adding a VALIDATION block to the config file as well.
--Steve
On Fri, Nov 17, 2023 at 3:37 PM Lime, Steve D (MNIT) via MapServer-dev <
mapserver-dev at lists.osgeo.org> wrote:
> Hi Jukka: Yeah, this is a potential area for improvement. We’ve be using a
> couple of strategies where I work. One being includes plus runtime subs so
> you can embed replacement strings as necessary, similar to your examples.
> The environment file gets included in a validation block and you set both a
> default and validation patterns for each value:
> “dbhost_default” “some.database.host”
> “dbhost” “^some\.database\.host$”
> So dbhost can only be the one value. I feels cleaner just write things the
> way you suggest. However, it feels wrong to have to set a value twice – and
> is potentially error prone in a bad way. Plus, there’s no connection to the
> environment. I’m not a huge fan.
> The other approach is using a pre-processor to essentially compile a
> mapfile into a final version. We’re using YAML + mappyfile to create an
> environment-specific version of the mapfile. The YAML definition can
> consist of constants plus references to environment variables. There is
> loads of potential here but deployment in different environments requires a
> compilation step plus a working Python environment.
> So, I can see value in a VARIABLES block or reference to a file. Could
> also do that at the config file level instead. Beyond loading the hash
> somehow, one would need a method to apply the variables in a limited
> fashion, probably while the mapfile is being parsed. So, load the DATA
> value and then apply variables or something like that.
> This warrants an RFC I think…
> --Steve
> *From:* MapServer-dev <mapserver-dev-bounces at lists.osgeo.org> *On Behalf
> Of *Rahkonen Jukka via MapServer-dev
> *Sent:* Thursday, November 9, 2023 5:08 PM
> *To:* 'mapserver-dev at lists.osgeo.org' <mapserver-dev at lists.osgeo.org>
> *Subject:* [MapServer-dev] Variables in mapfiles
> Hi,
> When I was reading the old bug reports in the OSGeo code sprint this 20
> years old one https://github.com/MapServer/MapServer/issues/408 from year
> 2003 did not feel rotten at all. And the last comment
> https://github.com/MapServer/MapServer/issues/408#issuecomment-1065080140
> has received 5 thumbs up within 1 year which shows great user activity by
> our standards.
> I think that environmental variables may be too strong tool for this
> purpose. For example, are those who write mapfiles allowed to set env
> variables in managed environments? Maybe something similar to SYMBOLSET and
> INCLUDE would be easier to use.
> As an example, I found a pretty good bug report that includes a mapfile
> and data, but for testing the mapfile on my Windows machine I need to make
> a few edits.
> CONFIG "PROJ_LIB" "/usr/local/share/proj"
> I am on Windows and my proj is in some other
> place
> WMS_ONLINERESOURCE http://odroid1:5001/
> wms_service_onlineresource http://odroid1:5001/
> I don’t understand the difference between those
> two, but anyway I run Mapserver at http://localhost:8060/...
> DATA "./bug-report.xml"
> I prefer to keep data in different place than
> mapfiles
> DATA "./data-in-31287"
> Same for this shapefile data
> What if we could write non-fixed paths and other items into the mapfile
> like
> CONFIG "PROJ_LIB" "%proj_lib%"
> WMS_ONLINERESOURCE "%onlineresource_test%"
> wms_service_onlineresource "%onlineresource_test%"
> DATA "%datapath_test%/bug-report.xml"
> DATA "%datapath_test%/data-in-31287"
> MAPVARIABLES "map_variables.txt"
> END # mapfile
> The contents of "map_variables.txt"
> //Some magic
> proj_lib [value]
> onlineresource_test [value]
> onlineresource_qa [value]
> onlineresourse_production [value]
> datapath_test [value]
> datapath_qa [value]
> datapath_production [value]
> symbolset_topomap [value]
> symbolset_citymap [value]
> etc.
> A difference to INCLUDE is that while the whole include file is slipped
> inside the mapfile the variable file could be a dictionary. That would
> allow forwarding the mapfile from test to qa to production easily. And when
> the IP address of test servers change an edit in one place would be enough.
> It would still be possible to use separate "map_variables_testing.txt" for
> testing if it feels better.
> I admit that there are alternative scenarios via INCLUDE or config file or
> environmental variables.
> -Jukka Rahkonen-
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20231226/e577257e/attachment.htm>
More information about the MapServer-dev
