[MapServer-dev] Use Mapfile CONFIG keys in URLs
Seth G
sethg at geographika.co.uk
Mon Mar 6 05:21:36 PST 2023
Hi devs,
The OGC Features API introduced in MapServer 8.0 allows accessing Mapfiles using keys in the config file:
URL: http://example.com/mykey/ogcapi/collections/foo/items.
Config file:
CONFIG
MAPS
mykey "/path/to/mapfile"
END
END
For all other requests you have to use the format http://example.com/?map=mykey&request=WMS...
I think it would be nice to be able to use the same approach as OGC Features API to allow the key to be used as part of the URL e.g. a WMS request could be accessed using: http://example.com/mykey/?request=WMS...
The changes to allow this seem to be minimal (with work to be done on tests and docs) - see [1]
Does anyone have any thoughts or reservations on adopting this approach?
Seth
[1] https://github.com/MapServer/MapServer/compare/main...geographika:mapserver:mapfile-key-url
web:https://geographika.net
twitter: @geographika
More information about the MapServer-dev
