[MapServer-dev] Use Mapfile CONFIG keys in URLs
Steve Lime
sdlime at gmail.com
Mon Mar 6 14:39:41 PST 2023
Hmmm... so if path_info contains exactly one value, use it for the map=
value. I could get behind that. Nice and clean.
On Mon, Mar 6, 2023 at 7:22 AM Seth G <sethg at geographika.co.uk> wrote:
> Hi devs,
> The OGC Features API introduced in MapServer 8.0 allows accessing Mapfiles
> using keys in the config file:
> URL: http://example.com/mykey/ogcapi/collections/foo/items.
> Config file:
> CONFIG
> MAPS
> mykey "/path/to/mapfile"
> END
> END
> For all other requests you have to use the format
> http://example.com/?map=mykey&request=WMS...
> I think it would be nice to be able to use the same approach as OGC
> Features API to allow the key to be used as part of the URL e.g. a WMS
> request could be accessed using: http://example.com/mykey/?request=WMS...
> The changes to allow this seem to be minimal (with work to be done on
> tests and docs) - see [1]
> Does anyone have any thoughts or reservations on adopting this approach?
> Seth
> [1]
> https://github.com/MapServer/MapServer/compare/main...geographika:mapserver:mapfile-key-url
> web:https://geographika.net
> twitter: @geographika
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20230306/1228c6a2/attachment.htm>
More information about the MapServer-dev
