[MapServer-dev] Use Mapfile CONFIG keys in URLs
Seth G
sethg at geographika.co.uk
Sat Mar 11 03:01:13 PST 2023
Hi Steve,
Yes that is pretty much it. As you can see from the branch there are minimal changes, and provides a "canonical" URL for all OGC services. I'll make a pull request next week and update the relevant tests.
Seth
web:https://geographika.net
twitter: @geographika
On Mon, Mar 6, 2023, at 11:39 PM, Steve Lime wrote:
> Hmmm... so if path_info contains exactly one value, use it for the map= value. I could get behind that. Nice and clean.
> On Mon, Mar 6, 2023 at 7:22 AM Seth G <sethg at geographika.co.uk> wrote:
>> Hi devs,
>> The OGC Features API introduced in MapServer 8.0 allows accessing Mapfiles using keys in the config file:
>> URL: http://example.com/mykey/ogcapi/collections/foo/items.
>> Config file:
>> CONFIG
>> MAPS
>> mykey "/path/to/mapfile"
>> END
>> END
>> For all other requests you have to use the format http://example.com/?map=mykey&request=WMS...
>> I think it would be nice to be able to use the same approach as OGC Features API to allow the key to be used as part of the URL e.g. a WMS request could be accessed using: http://example.com/mykey/?request=WMS...
>> The changes to allow this seem to be minimal (with work to be done on tests and docs) - see [1]
>> Does anyone have any thoughts or reservations on adopting this approach?
>> Seth
>> [1] https://github.com/MapServer/MapServer/compare/main...geographika:mapserver:mapfile-key-url
>> MapServer-dev mailing list
>> MapServer-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20230311/d520eae8/attachment.htm>
More information about the MapServer-dev
