[MapServer-dev] Custom projections for certain EPSG codes
Even Rouault even.rouault at spatialys.com
Thu Mar 9 06:31:35 PST 2023
Hi Jukka,
> Does it mean that the epsg file should contain entries for all the
> coordinate systems that our Mapserver supports for input and output,
> and that the proj.db database would then be completely skipped, with
> all the benefits that it has?
yes, that's really a trick for backward compatibility. Not something
that should be nominally used nowadays. As mentioned in
https://github.com/MapServer/MapServer/issues/6843#issuecomment-1462161146,
I don't reproduce any issue when trying to reproduce.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20230309/5ce5bde9/attachment.htm>
More information about the MapServer-dev mailing list
