[MapServer-dev] OGC API Features: some failures in CITE tests
Seth G sethg at geographika.co.uk
Thu Oct 19 04:37:14 PDT 2023
Hi Jukka,
With regards to:
>  • Wrong http status code: returns 400, should be 200
> https://demo.mapserver.org/cgi-bin/mapserv/localdemo/ogcapi/collections/countries/items?bbox=177.0000000%2C65.0000000%2C-177.0000000%2C70.0000000
Do you have a reference to why this should be HTTP 200 (Success)? If the bbox parameter is invalid then it is treated as other bad parameter settings and return HTTP 400 e.g. https://demo.mapserver.org/cgi-bin/mapserv/localdemo/ogcapi/collections/countries/items?f=html&limit=10&offset=a
The spec also refers to HTTP 400 - https://docs.ogc.org/is/17-069r3/17-069r3.html#query_parameters
Or have I misunderstood the issue?
Seth
web:https://geographika.net & https://mapserverstudio.net
twitter: @geographika
On Wed, Oct 18, 2023, at 9:21 AM, Rahkonen Jukka via MapServer-dev wrote:
> Hi,
> I used the OGC Teamengine for testing our OGCFeat demo at https://demo.mapserver.org/cgi-bin/mapserv/localdemo/ogcapi.
> The validator found a few issues:
>  • Some tests fail because the service returns invalid geometries. Mapserver actually works right but because of invalid topology the validator fails. For example a geometry of the France multipolygon, somewhere near the French Guiana is invalid due to duplicated vertices at  POINT (-52.939657 2.124858). The BBOX in the test was BBOX= -1.5000000,50.0000000,1.5000000,53.0000000. There are other similar geometries showing self-intersection.
>  • If query contains an unknown parameter then our server sends data, but it should error out and send a http 400 error.
> Test request: https://demo.mapserver.org/cgi-bin/mapserv/localdemo/ogcapi/collections/ocean-labels/items?unknownQueryParameter13515=1
>  • The Content-Crs header is missing when the request is using the default crs. Test query: https://demo.mapserver.org/cgi-bin/mapserv/localdemo/ogcapi/collections/ocean/items?f=json
> I have looked at the extra parameter thing from the standard and from the discussions in the OGC GitHub. Notes from the research:
> The server SHALL respond with a response with the status code `400`, if the request URI includes a query parameter that is not specified in the API definition. For omitting unknown “vendor specific” parameters is must be defined in the API as
> in: query
> schema:
> type: object
> additionalProperties: true
> style: form
> If a server wants to support vendor specific parameters, these have to be explicitly declared in the API definition. If OpenAPI is used to represent the API definition, a capability exists to allow additional parameters without explicitly declaring them. That is, parameters that have not been explicitly specified in the API definition for the operation will be ignored.
> With minor changes Mapserver could get the certificates for OGC API Features Core and CRS. But I wonder what to do with the demo service. The server that is used for the CITE tests must be available online. We could try to fix the existing Natural Earth data and service so that it sends topologically valid geometries. Another option would be to set up another service instance for CITE tests with some known valid datasets.
> -Jukka Rahkonen-
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20231019/f2d612cd/attachment.htm>
More information about the MapServer-dev mailing list
