[MapServer-dev] OGC API Features: some failures in CITE tests
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Oct 18 10:21:31 PDT 2023
Hi Jukka,
Can you file that as a docs ticket so I can tackle it?
https://github.com/MapServer/MapServer-documentation/issues thanks,
-jeff
On 2023-10-18 12:48 p.m., Rahkonen Jukka via MapServer-dev wrote:
> I cannot see that oga mode documented
> https://www.mapserver.org/ogc/ogc_api.html
> -Jukka-
> *Lähettäjä:* Lime, Steve D (MNIT) <steve.lime at state.mn.us>
> *Lähetetty:* keskiviikko 18. lokakuuta 2023 18.09
> *Vastaanottaja:* Seth G <sethg at geographika.co.uk>; Rahkonen Jukka
> <jukka.rahkonen at maanmittauslaitos.fi>; MapServer Devs
> <MapServer-dev at lists.osgeo.org>
> *Aihe:* RE: [MapServer-dev] OGC API Features: some failures in CITE tests
> There is an “oga_compliance_mode” metadata element already enabled (at
> the WEB level) that will throw an exception on requests w/extra
> parameters. --Steve
> *From:*MapServer-dev <mapserver-dev-bounces at lists.osgeo.org
> <mailto:mapserver-dev-bounces at lists.osgeo.org>> *On Behalf Of *Seth G
> via MapServer-dev
> *Sent:* Wednesday, October 18, 2023 5:15 AM
> *To:* Rahkonen Jukka <jukka.rahkonen at maanmittauslaitos.fi
> <mailto:jukka.rahkonen at maanmittauslaitos.fi>>; MapServer Devs
> <MapServer-dev at lists.osgeo.org <mailto:MapServer-dev at lists.osgeo.org>>
> *Subject:* Re: [MapServer-dev] OGC API Features: some failures in CITE tests
> Thanks Jukka for testing with the validator.
> The extra parameters issue has been discussed before - a major issue is
> that all cookie parameters are seen as request parameters. See [1] and
> [2]. I'm not sure if it has been addressed in pygeoapi which is the
> reference implementation. MapServer also uses parameters for
> runtime-subsitution so enforcing no extra parameters will break a lot of
> MapServer workflows.
> I think it was suggested adding a "strict" WEB METADATA item that would
> return a 400 error when extra parameters were encountered - this would
> allow tests to pass fo a particular server.
> What is the service meant to do with invalid geometry such as that
> polygon - throw an error?
> It would be good to open the other items as issues on GitHub to fix.
> Seth
> [1]
> https://lists.osgeo.org/pipermail/mapserver-dev/2021-September/016620.html <https://lists.osgeo.org/pipermail/mapserver-dev/2021-September/016620.html>
> [2]
> https://github.com/MapServer/MapServer/pull/6400#issuecomment-936458600
> <https://github.com/MapServer/MapServer/pull/6400#issuecomment-936458600>
> web:https://geographika.net <https://geographika.net/> &
> https://mapserverstudio.net <https://mapserverstudio.net/>
> twitter: @geographika
> On Wed, Oct 18, 2023, at 9:21 AM, Rahkonen Jukka via MapServer-dev wrote:
>     Hi,
>     I used the OGC Teamengine for testing our OGCFeat demo at
>     https://demo.mapserver.org/cgi-bin/mapserv/localdemo/ogcapi
>     <https://demo.mapserver.org/cgi-bin/mapserv/localdemo/ogcapi>.
>     The validator found a few issues:
>       * Wrong http status code: returns 400, should be 200
>     https://demo.mapserver.org/cgi-bin/mapserv/localdemo/ogcapi/collections/countries/items?bbox=177.0000000%2C65.0000000%2C-177.0000000%2C70.0000000 <https://demo.mapserver.org/cgi-bin/mapserv/localdemo/ogcapi/collections/countries/items?bbox=177.0000000%2C65.0000000%2C-177.0000000%2C70.0000000>
>       * Some tests fail because the service returns invalid geometries.
>         Mapserver actually works right but because of invalid topology
>         the validator fails. For example a geometry of the France
>         multipolygon, somewhere near the French Guiana is invalid due to
>         duplicated vertices at  POINT (-52.939657 2.124858). The BBOX in
>         the test was BBOX= -1.5000000,50.0000000,1.5000000,53.0000000.
>         There are other similar geometries showing self-intersection.
>       * If query contains an unknown parameter then our server sends
>         data, but it should error out and send a http 400 error.
>     Test request:
>     https://demo.mapserver.org/cgi-bin/mapserv/localdemo/ogcapi/collections/ocean-labels/items?unknownQueryParameter13515=1 <https://demo.mapserver.org/cgi-bin/mapserv/localdemo/ogcapi/collections/ocean-labels/items?unknownQueryParameter13515=1>
>       * The Content-Crs header is missing when the request is using the
>         default crs. Test query:
>         https://demo.mapserver.org/cgi-bin/mapserv/localdemo/ogcapi/collections/ocean/items?f=json <https://demo.mapserver.org/cgi-bin/mapserv/localdemo/ogcapi/collections/ocean/items?f=json>
>     I have looked at the extra parameter thing from the standard and
>     from the discussions in the OGC GitHub. Notes from the research:
>     The server SHALL respond with a response with the status code 400,
>     if the request URI includes a query parameter that is not specified
>     in the API definition. For omitting unknown “vendor specific”
>     parameters is must be defined in the API as
>     in: query
>     schema:
>     type: object
>     additionalProperties: true
>     style: form
>     If a server wants to support vendor specific parameters, these have
>     to be explicitly declared in the API definition. If OpenAPI is used
>     to represent the API definition, a capability exists to allow
>     additional parameters without explicitly declaring them. That is,
>     parameters that have not been explicitly specified in the API
>     definition for the operation will be ignored.
>     With minor changes Mapserver could get the certificates for OGC API
>     Features Core and CRS. But I wonder what to do with the demo
>     service. The server that is used for the CITE tests must be
>     available online. We could try to fix the existing Natural Earth
>     data and service so that it sends topologically valid geometries.
>     Another option would be to set up another service instance for CITE
>     tests with some known valid datasets.
>     -Jukka Rahkonen-
>     _______________________________________________
>     MapServer-dev mailing list
>     https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>     <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
Jeff McKenna
GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
co-founder of FOSS4G
http://gatewaygeo.com/
More information about the MapServer-dev mailing list
